04-23-2018, 14:46 | #16 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Kishtwar/Islamaabad j&k Age: 45
Member: 326228 Status: Offline Thanks Meter: 31 | miracle eagle eye 3.71 open port error (World's First Fuzzy Logic Based Tool) Update:18-02-10 Firmware Version:1.15 Connected OK. Fuzzy Logic Method is very safe and reliable ! License Expire Date: 2018-12-04 Error ID: Update not Fileexists 1. Phone switched Off 2. Press Vol+ or Vol-,Connect Mobile with USB Cable Or use specialized USB Cable,Enter Edl(9008) mode 3. Scan Port Definition Applied Connecting to Phone,Wait.. Open port error, Port is occupied or non-existent >>Please RePower on & off why I am getting this error every time after updating to 3.71 miracle eagle eye |
04-24-2018, 09:00 | #18 (permalink) |
Registered User Join Date: Apr 2008
Member: 760450 Status: Offline Thanks Meter: 4 | please help mi miracle eagle eye 2.71 don't work >>Timeout. Please Check Pinouts or ReDo >>Timeout. Please Check Pinouts or ReDo >>Timeout. Please Check Pinouts or ReDo unstable comport error for mtk after update ver.2.71 please solved this miracle team |
04-25-2018, 06:47 | #21 (permalink) |
Member: 326228 Status: Offline Thanks Meter: 31 | hi every one I found a solution for miracle eagle eye v2.71 which was not working properly first install miracle box setup 2.72 from here Setup_Miracle_Box_v272 now copy box_data from installed folder and save it to another folder now remove miracle box setup 2.72 now extract miracle eagle eye setup to c drive and delete box_data from the extracted setup now copy the folder that was copied from miracle box 2.72 and paste it tomiracle eagle eye folder now run miracle eagle eye your box firmware will be upgraded to 1.16 and your problem will be solved if your problem is solved pray for my better health as speedy recovery thankyou |
04-26-2018, 18:22 | #29 (permalink) |
Junior Member Join Date: Nov 2016 Location: Chittagong city.
Member: 2647291 Status: Offline Thanks Meter: 9 | i try this way that you mentioned ((mkteletronics)) but dont work miracle eagle 2.71 shown on pic https://drive.google.com/open?id=1NP...BzEs78loA_jEqz |
