Old 08-02-2013, 01:21   #1 (permalink)
.:Abdul-Basit:.'s Avatar
Member: 1727711
Sonork: 100.1590443
Thanks Meter: 1,305
Arrow Ufs Hwk Update Problem Solution
Hi
Friends i have seen some users complaint me that they cannot update their new ealge eye box on ufs hwk software
solution is already posted in their section
FIRST FORGET ALL OLD SETUP
THEN REMOVE OR UNINSTALL OLD SETUP FROM PC
NOW DOWNLOAD BELOW SETUP
NOW OPEN THIS SETUP UFS PANEL
  • CLICK ON CHECK BOX
  • CLICK ON UPDATE BOX
  • AGAIN CHECK BOX
  • NOW CLICK CHECK SERVER
  • NOW U CAN INSTALL & WAIT UNTIL COMPLETE PROCESS LIKE THIS
Regards
The Following 8 Users Say Thank You to .:Abdul-Basit:. For This Useful Post:
Old 08-02-2013, 11:56   #2 (permalink)
Member: 478609
HWK: NOT AUTHORISED, Update Box
Bad IX: ABCD
Failed: -6
Authentication stage error: Connection Closed Gracefully.
The Following User Says Thank You to bittukhan For This Useful Post:
Old 08-06-2013, 00:49   #3 (permalink)
Member: 1864391
Thanks Meter: 3
same problemmm.....Connection Closed Gracefully.
The Following User Says Thank You to Hi-Fi Computer For This Useful Post:
Old 08-07-2013, 14:44   #4 (permalink)
Member: 1727711
Sonork: 100.1590443
Thanks Meter: 1,305
@ bittukhan
@ Hi-Fi Computer
Try now server was closed that time
Regards
The Following User Says Thank You to .:Abdul-Basit:. For This Useful Post:
Old 08-08-2013, 08:08   #5 (permalink)
Member: 142637
am having the same problem too
Old 08-08-2013, 08:46   #6 (permalink)
mayank.gupta's Avatar
Member: 966792
Sonork: 100.1602610
Thanks Meter: 197
None Authorised Copy of Software Detected, Reinstall
Bad IX: AB1D
Failed: 100
Your IP: 123.-------------
Support: Account Ok
Wrong Instalation, Try to Use [Install] in Software Page
The Following 2 Users Say Thank You to mayank.gupta For This Useful Post:
Old 08-08-2013, 16:12   #7 (permalink)
Member: 1974134
same here (failed 6)
Old 08-08-2013, 16:24   #8 (permalink)
Member: 207561
Thanks Meter: 693
Uninstall old ufsx setup and Driver,,,,,,,,,,,,
100000000000000000000000% Salution here.
ist ,,Click Hardware tab ,1 scan Box,,,2 Check box 3Update box ,,,,,,,,,,,
Than Click Software Tab,,Check Server 2 Install ,,,,,,,,,,,
ok ok ok,
Try
Old 08-08-2013, 19:25   #9 (permalink)
siddhu nokia's Avatar
Member: 1166487
Sonork: 100.1673527
Thanks Meter: 5
i facing same problem bros i will try thk u
Old 08-11-2013, 08:56   #10 (permalink)
Mc.Manik's Avatar
Member: 1261483
Sonork: 100.1644685
Thanks Meter: 119
use 2.3.01 problem solve 100%..........
Old 08-15-2013, 07:41   #11 (permalink)
taimoorkhan's Avatar
Member: 101548
Sonork: 100.1611535
Thanks Meter: 209
before my ufs working good but when i update i got this error..
Account Closed by Admin
User Id not Allowed
The Following User Says Thank You to taimoorkhan For This Useful Post:
Old 08-16-2013, 12:18   #12 (permalink)
Member: 1396252
Box: 1 Location: 66 Serial: 76159
UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 76159
HID: 5DCA5D28416000EE, HWK: A1.04-PRO1
Your IP: 119.235.54.179
Support: Account Ok
REST: Ok
UFSx: UFS3 SarasSoft, USB S/N: 76159
NVML: OK
BOOT: UFxBoot V2.2 (c) SarasSoft 2003.
CORE: UFS_USB V2.8 (c) SarasSoft 2007.
SERN: 76159
LIC5: True
BOXK: 1
Connection to server failed. Socket Error # 10060
Connection timed out.(A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
The Following User Says Thank You to naveengod For This Useful Post:
Old 08-19-2013, 19:47   #13 (permalink)
Member: 850556
same problem pls help me
Bad IX: ABCD
Failed: -6
same problem pls help me brother...
Old 08-19-2013, 20:00   #14 (permalink)
Member: 976081
same poblem brooooooooooooo plzzzzzzzzzzzz help me 9437287476
Old 08-20-2013, 09:31   #15 (permalink)
Member: 900395
Sonork: farid
Thanks Meter: 5
I THINK UFS or HWK is dead now
NO MORE UPDATE, I WAS TRYING 15 Days and the server Error.
The Following User Says Thank You to farid_bbr For This Useful Post:
Page generated in 0.44566 seconds with 8 queries
