Old 09-06-2013, 15:37   #31 (permalink)
Member: 541042
Thanks Meter: 518
Open Eyes and Read and Post in right Support Thread
Read Sticky Thread for Fix error 20/32
Old 09-09-2013, 11:54   #32 (permalink)
.:Abdul-Basit:.'s Avatar
Member: 1727711
Sonork: 100.1590443
Thanks Meter: 1,305
Hi
Anyone Can Contact With Me To Solve Thier Box Update Problem I Will Do Manually
Regards
Old 09-09-2013, 16:30   #33 (permalink)
binaybiswas's Avatar
Member: 1093574
Sonork: 100.1646163
Thanks Meter: 473
Originally Posted by nomilove09 View Post
but i steel this problem i changed port
same problem failed 6 , BOX_AUTH_ERROR: 20 and start updating
like this
App: UFSx (HWK) Control Panel v 2.3.0.2 by SarasSoft
Box: 1 Location: 561 Serial: -----
UFxBoot V2.2 (c) SarasSoft 2003., Id: ----------
UFS_USB V2.8 (c) SarasSoft 2007., Sn: ------
HID: ---------------, HWK: -----------
BOX_AUTH_ERROR: 20
HWK: NOT AUTHORISED, Update Box
Bad IX: ABCD
Failed: -6
Box: 1 Location: 561 Serial: ------
HID: ------------------, HWK: -----------
BOX_AUTH_ERROR: 20
Your IP: -------------
Support: Account Ok
REST: Ok
UFSx: UFS3 SarasSoft, USB S/N: ------
NVML: Ok
than hang after some time show box error . 00000080
And i am trying since 1 month before all thing ok but i update new v so problems and problems .
Box connect with Mother Board USB Port. Must be Use good AB cable.
The Following 3 Users Say Thank You to binaybiswas For This Useful Post:
Old 09-16-2013, 08:10   #34 (permalink)
..:::GSM CLUB™:::..'s Avatar
Member: 859030
Sonork: 100.1619336
Thanks Meter: 310
Question
UFxBoot V2.2 (c) SarasSoft 2003., Id: xxxxxx
UFS_USB V2.8 (c) SarasSoft 2007., Sn: xxxxx
LIC: True
Authentication stage error: Server reported error: No more upgrade logs. Please contact your reseller!
plz help me
how to update my hwk?
Old 09-16-2013, 10:27   #35 (permalink)
Moderator
Deepesh Sharma's Avatar
Member: 1301233
Sonork: 100.1614172
Thanks Meter: 8,809
Originally Posted by parbes View Post
ufxboot v2.2 (c) sarassoft 2003., id: Xxxxxx
ufs_usb v2.8 (c) sarassoft 2007., sn: Xxxxx
lic: True
authentication stage error: Server reported error: No more upgrade logs. Please contact your reseller!
plz help me
contact with me
i wll see via teamviewer
why you facing this problem
Old 09-16-2013, 16:08   #36 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 8,837
Talking
LIC: True
plz help me
I Cant Understand Why You Are Cant Success
Today I'M Successful Install My Eagle Eye + HWK Very Easily To My Another Pc
Here is Upgrade Log:-
CPU: GenuineIntel
Platform: Windows NT 5.1 (Build 2600 Service Pack 3)
Versions: Ufs2xx.dll 3.2.4, Ufs2xx.sys 2.8.14
C:\Program Files
C:\Program Files\Common Files
Nokia Path not Found, Set to: C:\Program Files\Nokia\Phoenix
C:\Documents and Settings\786\Desktop
C:\Documents and Settings\786\Start Menu\Programs
Box: 1 Location: 1057 Serial: 9xxxx
UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 9xxxx
HID: 1Cxxxxxxxxxxxxxx, HWK: A1.04-PRO1
LIC: True
Your IP: 203.223.94.184
Support: Account Ok
REST: Ok
UFSx: UFS3 SarasSoft, USB S/N: 9xxxx
NVML: Ok
BOOT: UFxBoot V2.2 (c) SarasSoft 2003.
CORE: UFS_USB V2.8 (c) SarasSoft 2007.
SERN: 93793
LIC5: True
BOXK: 1
LIC: True
Authentication successfull.
Upgrade client is up-to-date.
Upgrade process completed.
Bro:- Palash Ahammad
Miracle Box Team
Old 09-18-2013, 16:20   #37 (permalink)
Member: 1335538
Box: 1 Location: 785 Serial: 90182
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 90182
HID: 147E64F8426000A7, HWK: A1.04-PRO1
LIC: True
None Authorised Copy of Software Detected, Reinstall
Bad IX: AB11
Failed: 102
Support: Server Communication Error (Check Firewall and TCP/IP DNS Server Settings, try to use: 8.8.8.8 and 8.8.4.4)
Old 09-19-2013, 05:00   #38 (permalink)
Moderator
Member: 1162626
Thanks Meter: 8,837
LIC: True
Bad IX: AB11
Failed: 102
Must Be Try With Disable Your Antivirus & Windows Firewall.
Than Try To Update Your Hwk....................
Hopefully Willbe Success.
Miracle Box Team
Old 09-19-2013, 11:40   #39 (permalink)
Member: 1532104
hi
i have problem
i updated and install successfully but i want to open show this error
bad environment: -1 (bad driver)
current usb driver's not authorised
sys: 2.6.0
dll: 3.1.19
ithink need new usb driver
Old 09-19-2013, 12:43   #40 (permalink)
Member: 704044
Thanks Meter: 134
Sir my eagle eye hwk not update always says support error and reinstall support suite
Sir my eagle eye hwk not update always says support error and reinstall support suite. Kindly pls help
Old 09-19-2013, 12:49   #41 (permalink)
Moderator
Member: 1162626
Thanks Meter: 8,837
Originally Posted by naser_saz88 View Post
hi
i have problem
sys: 2.6.0
dll: 3.1.19
1'st Remove Your Old UFS Driver From Control Panel.
Than Recover / Update Your Ufs Driver From C:\Program Files\SarasSoft\UFS\UFS_USB_Driver
Just Post Here Your Success Result Hopefully You Willbe Done.
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post:
Old 09-20-2013, 02:34   #42 (permalink)
Member: 1231099
Box: 1 Location: 50 Serial: 77326
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 77326
HID: 3BF83DB641600088, HWK: A1.04-PRO1
BOX_AUTH_ERROR: 20
Bad IX: ABCD
Failed: -6
Your IP: 190.226.145.30
Support: Account Ok
Something Wrong, Try to Use [Update Box]
BOX_AUTH_ERROR: 20
Support: Account Ok
REST: Ok
UFSx: UFS3 SarasSoft, USB S/N: 77326
NVML: Ok
error: BOX_ERROR: 00000080.
Help me please
Old 09-20-2013, 07:19   #43 (permalink)
Member: 957188
Sonork: 1654550:ali
Thanks Meter: 12
please help me friends
Old 09-20-2013, 23:40   #44 (permalink)
Member: 1727711
Sonork: 100.1590443
Thanks Meter: 1,305
Driver issue contact with me i will solve ur problem
Regards
Old 09-21-2013, 02:56   #45 (permalink)
Member: 1232828
Sonork: 100.1647663
Thanks Meter: 48
your usb driver is here remove old ufs driver And install new driver 100% solution UFS_USB_Driver.rar
The Following 2 Users Say Thank You to janu_shivam For This Useful Post:
Page generated in 0.36679 seconds with 8 queries
