01-31-2014, 02:29 | #1 (permalink) |
Product Supporter Join Date: Feb 2012 Location: KB GSM STORE
Member: 1727711 Status: Offline Sonork: 100.1590443 Thanks Meter: 1,331 | How To Flash Your HTC Phones With GsmCocktail ( Guide ) I have seen many of friends are stuck flashing HTC Phones stuck on logo & other problems , because of they don't know which file is correct for their phone. Let me explain you,what you have to do first when you get htc in your shop. 1st of all u need to put your phone in fastboot mode it is simple by pressing volume down + power button your phone will go into hboot mode then pressing power button again you will go in fastboot mode which is show on screen too like show in pic below now when u go in fastboot mode put cable inside phone and install drivers which is adb drivers u can found drivers easily in gsmcocktail support or download it from here : http://forum.gsmhosting.com/vbb/f754...014-a-1697080/ after installing drivers open HTC Android Tool click read info button after getting read info u need to focus on 3 things 1st Security is on or off you can see this on fastboot as well 2nd device country 3rd main version if your security is on ( S-ON ) then you need to use this method you need to make sure both things should be correct for your rom which u want to download from support for flash your phone with gsmcocktail dongle you can download from shell easily or u can download it from support too here is tutorial : http://forum.gsmhosting.com/vbb/9725117-post5.html once you found your correct rom matched with device country cid and main version you will be able to flash your rom . and if your phone security is off ( S-Off) then you dont have to match both things u can flash it with any rom any main version etc Note : if you do not found your correct rom matched with device counrty or main version or you found rom like main version is ok but device country is not same then rom will not work so in that case you need to use the cmw method custom rom flashing guide posted below http://forum.gsmhosting.com/vbb/f754...guide-1746101/ any more questions or further help need i m ready to answer Best Regards Abdul Basit ( KBGSMLAB) GsmCocktail Team |
The Following 10 Users Say Thank You to .:Abdul-Basit:. For This Useful Post: |
02-02-2014, 12:55 | #3 (permalink) | |
Member: 1727711 Status: Offline Sonork: 100.1590443 Thanks Meter: 1,331 | Quote:
S-off method is already discussed and if u want to know about particular model of htc s-off let me know details phone model name etc so ill guide u about it more Best Regards Abdul Basit ( KBGSMLAB ) | |
03-06-2014, 11:19 | #4 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2096526 Status: Offline Thanks Meter: 0 | how to flash Checking Device Battery BATTERY-STATUS: GOOD MID: PC10***** VERSION-BOOTLOADER: 0.85.0013 VERSION-MAIN: 2.42.405.4 CID: 11111111 Erasing cache partition... File name: RUU_Vision_Gingerbread_S_HTC_WWE_2.42.405.2_Radio_ 12.56.60.25_26.10.04.03_M_release_199043_signed.zi p Please Wait... sending 'zip' (260221 KB)... Done writing 'zip'... writing 'zip'... zip header checking... zip info parsing... FAILED (remote: 24 parsing android-info fail) Elapsed: 55 seconds |
04-01-2014, 15:44 | #5 (permalink) | |
change firmware and try again or flash it with ruu Br | |
