09-10-2013, 03:41 | #16 (permalink) | |
Freak Poster Join Date: May 2006 Location: Malaysia Kuala Lumpur
Member: 276082 Status: Offline Thanks Meter: 113 | Quote:
usually all nano sim will not support due to simcard compatible issue with all other sim proxy solution, but you can try change to a normal type of simcard and cut it to nano to try, but you need to remove the iR0se. this iR0se solution mainly for nano sim, 128k sim or 4g simcard that not support and after patch it will able to use. | |
09-10-2013, 07:34 | #17 (permalink) | |
Junior Member Join Date: Sep 2013
Member: 2021876 Status: Offline Thanks Meter: 0 | Quote:
If i get a normal sim and i cut it you think i should be able to use 3G on my provider. Note:I used 3G internet connection before but not with this provider. And another question:If i ask for another sim should i tell them what kind of sim for eg: sim that provides me only 3G internet? What kind of sims should provide me 3G internet and not only E (Like now) Thank you in advance. | |
09-10-2013, 08:27 | #18 (permalink) | |
all this problem is simcard compatible issue, is nothing wrong with your carrier sim, you have to try with your luck by getting another basic type of sim cut it to nano and try it. if it no service then u need to use iR0se. iR0se already install in your phone, even u delete it, it will still there until u format it. they have another solution without format your phone to switch nano or non nano sim, but it need to buy a patch to work, i can't publish here.. it is from other compatible, hope you understand | |
09-10-2013, 09:48 | #20 (permalink) |
Member: 2021876 Status: Offline Thanks Meter: 0 | My iPhone 4s uses micro sim and seems too strange that it works with some sims and not with others i will try with another sim maybe i get more luccky than with the last 2 sims. Any solution will come for this on iOs 7.0 ? We need new x sims for the iOs 7.0 upgrades ? Anyway unistalling iRose without erasing iPhone ? |
09-10-2013, 12:08 | #21 (permalink) |
Member: 2021876 Status: Offline Thanks Meter: 0 | Ok i solved the problem (after destroying 3-4 sims). I just went to my carrier and changed my sim card 4G LTE 128k with a GSMA 64k sim (aka old tech) at least in this way i can use 3G,MMS,SMS,Call without losing my previous number. Maybe this might work for iPhone 5 too if you don't want to use 4G internet. A temporary solution till some update will come for 4G. Thank you for all answers, Gabri3l |
09-10-2013, 21:58 | #22 (permalink) |
Junior Member Join Date: Aug 2013
Member: 2015252 Status: Offline Thanks Meter: 0 | I was not so lucky like Gabri3l, I got a normal sim, I cut it, I uninstalled iR0se and 3G is not working, signal - NO SERVICE - signal, is not a network stability. Now I want again to install iR0se, but when I press install button from iTools, nothing was happened. I read some posts upper that iR0se is installed until format the phone, there is other option to reinstall it or to find it, without losing phone content? Thanks / Alex |
09-11-2013, 04:06 | #23 (permalink) |
Member: 2021876 Status: Offline Thanks Meter: 0 | I needed to reset my iphone to unistall irose. But try with a GSMA 64k sim. I tried 5 sims just for test and all worked. Try normal sims then cut them by your self. Maybe restoring your iphone from a backup might unistall irose. Irose is useful to make 128k sims work but only on EDGE. Whats the points using 128k sims with EDGE when you use 64k ones with 3G. 128k sims are good if want to use 4G LTE but since now that is not provided i prefer old sims. |
09-11-2013, 06:51 | #24 (permalink) | |
Member: 2015252 Status: Offline Thanks Meter: 0 | Quote:
Note: I uninstalled iR0se and I deleted the profiles created with iR0se in settings. other hints ? BR / Alex | |
09-11-2013, 07:51 | #25 (permalink) |
Member: 2021876 Status: Offline Thanks Meter: 0 | iRose stay on your iphone even after you delete it, it will stay there until u format it, at least this is what a user here said me, thats why i reseted phone. I don't know if iRose is giving you the current problem or not unfortunately Make a backup and reset your iphone to test it. |
09-11-2013, 08:42 | #26 (permalink) | |
Which one ? BR / Alex | |
09-11-2013, 09:47 | #28 (permalink) | |
Also remove all the profiles from Settings > General > Profiles ? SMS, CALLS, E is working with patch and a 64k sim cut into a nano-sim, but no 3G. I will try again to disable iR0se, and to see if works. BR / Alex | |
09-12-2013, 20:16 | #30 (permalink) |
Member: 2024251 Status: Offline Thanks Meter: 0 | How can I install an .ipa file? There is no way to jailbreak my device I have iPhone 4s, 6.1.3, my Carrier is Kyivstar, Ukraine, and there are no signal bars, just a name of my carrier. Have latest 420 XSIm. |
