Siemens-Benq RingTones and WallPapers NO Unlocking or Flashing threads here, this section for RingTones, Wall Papers, Games and other Staff. |
06-07-2005, 14:46 | #1 (permalink) |
Insane Poster Join Date: Apr 2005 Age: 45
Member: 141287 Status: Offline Thanks Meter: 5 | Here are some codes which can be useful!!!!!! *#06# - shows IMEI and some other usefull stuff *#0606# - shows if the phone is locked to any network Use without SIM card *#0000# - set language to default restrict sending your number (CLIR) disable sending number to others : *31# enable sending your number to other : #31# check status : *#31# temporary CLIR (only for next call) : #31#phone_number call number whit disabled CLIR: *31#phone_number shows calling number (CLIP) enable CLIP: *30# disable CLIP: #30# check status : *#30# call waiting enable: *43# disable: #43## check status : *#43# deblock PIN using PUK **05*PUK*newPIN*newPIN# to deblock PIN2, use PUK2: **052*PUK2*newPIN2*newPIN2# changing PIN PIN1: **04*old_PIN*new_PIN*new_PIN# PIN2: **042*old_PIN2*new_PIN2*new_PIN2# Change language with code : *#xxxx# then click on green button (call). You will type instead xxxx code of lang that you want. For example, code for Croatian is *#0385#, for Germany *#0049# and so on. However, if you type code which is not in the menu, it sets up automaticly to default language. Eastern egg At old Siemens C35, M35 i S35 type 2000 and save it as "History". Now there should apear picture with trees and list of programmers. Usefull... x65 extended video recording If you have a M65 or CX65 with FW12 or a S65 or SL65 with any FW you can do a trick to double to video recording limit. Go to Menu - Messages - Message setup - MMS setup - User settings, scroll down to 'Size indication'. Set all three to '000 kB' and the parameter behind to 'Lim'. Now go to video camera mode select Options - Settings and make sure 'Recording time' is set to 'MMS compatib'. You will now have either 1 minute or 1 minute and 15 seconds video recording depending on what phone you got. x55 operator logo If you don't know how to get rid of Operator Logo on new x55 series, here how you can do it. All you have to do is to download (right mouse click, and choose Save as) this picture and set it up as logo on your mobile. If you have the same problem with ST55, download this software to remove operator logo. Changing icons on x65 series For more info, click here. x65 Camera sound You would like to change your Camere sound on your x65? Nothing easier, you only need this software and a data cable. Once you have opened Filesyste, go to config/default folder and change Camera ClickMelody.mid melody, or just change name of it (that will remove any sound at all while takeing pictures) SX1 Deleting Reports (Message - Reports) 1-go to Menu 2-open Records 3-use joystick to move right 5-click on Left Soft Key (Options) 6-select Clear Records 7-click on Left Soft Key (Yes) Formating phone Turn your cell phone off. Press * & # - hold them and then turn your phone on by pressing phone red buttoon (ON/OFF). If you can reach stand by mode type *#7370# and then enter your security code, which is by default 12345 (unless you've changed it) Saving copy of your contacts 1. Turn your cell phone OFF-> Not necessary 2. Turn ON your phone holding Shift Key 3. Go to c:/system/data 4. Rename data directory (to dato or something else) 5. Enter c:/system/data and copy contacts.cdb 6. Copy contacts.cdb to MMC 7. Rename c:/system/dato to c:/system/data (DO NOT forgett to do this) Copying contacts to SIM 1-Go to contacts 2-Open one of contacts 3-Select the number 4-Select Option -> Copy to SIM ph.book Deleting or changing Operator Logo There are two ways to do this: 1. Manual Go to c:\system\apps\phone\oplogo\ (make directory if necessary) and copy any bitmap file (.bmp) sized 97 x 25 pixels. File must be named as MCC+MNC operator code. Reboot your phone 2. Automaticly Install FExplorer, run it, select bmp file (can be named anyhow), select Options/Set up as operator logo p.s. If you don't wan't to have any OP logo, just set 1x1.bmp file as OP logo FExplorer bmp 1x1 SX1 camera & IrDA SX1 camera like others el. cameras can see IR light, so you can use this to check if your IR is working. 1.Activate SX1 camera 2.Point some IR beam source into SX1 camera (some other mobile or TV remote control) 3.Now try to press some button on remote control... Listening FM radio on speaker - Once FM radio is started, click audio key on right side of SX1 (key next to camera key). - or just go to options/settings/audio/speaker Changing station - While listening to radio, quickly press button on SX1 headphones twice Useful codes *#0000# Date and FW version *#06# IMEI and other useful info *#7780# Return to factory settings *#7370# Phone formating *#330*0000# Reseting Network Barrings *#0606# SIM lock state *#2820# Bluetooth address enjoy.guys |
The Following 3 Users Say Thank You to austinchan For This Useful Post: |
06-07-2005, 16:41 | #2 (permalink) |
Crazy Poster Join Date: Jul 2004 Location: KSA
Member: 74223 Status: Offline Thanks Meter: 2 | restrict sending your number (CLIR) disable sending number to others : *31# enable sending your number to other : #31# check status : *#31# temporary CLIR (only for next call) : #31#phone_number call number whit disabled CLIR: *31#phone_number shows calling number (CLIP enjoy.guys This feature works in some network operator only. In our country it is not supported. By the way thanks for some of your codes. Some of them are useful. EMER |
The Following User Says Thank You to EMERSON For This Useful Post: |
06-28-2006, 17:42 | #5 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 201062 Status: Offline Thanks Meter: 37 | [quote=austinchan]Here are some codes which can be useful... .................................................. ... Formating phone Turn your cell phone off. Press * & # - hold them and then turn your phone on by pressing phone red buttoon (ON/OFF). If you can reach stand by mode type *#7370# and then enter your security code, which is by default 12345 (unless you've changed it) ............................................. Great boss it really worked on sx1 sx1 software is similar to nokia 6600, 6630 |
08-14-2006, 07:28 | #8 (permalink) | |
Junior Member Join Date: Sep 2005 Age: 33
Member: 181847 Status: Offline Thanks Meter: 0 | Quote:
Full Flash Files, Here are some links, add more if you can | simbirley | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 13 | 07-16-2013 08:33 |
****What new cheap phone to buy which can be used both on TATA and RELIANCE..??**** | joy4u | Various CDMA/TDMA Cell Phones | 0 | 02-22-2009 14:48 |
TO Mr.S.Mobi here are some Dictionarys to use and test from other testers | tsarkh | Infinity-Box | 2 | 02-04-2008 15:33 |
Which LCD's can be used in 3100? | atoo | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 12-13-2003 17:31 |
Which soft can be used for dead motorola??? | proxy_gsm | Motorola ODM | 2 | 10-03-2003 01:28 |
