Siemens-Benq RingTones and WallPapers NO Unlocking or Flashing threads here, this section for RingTones, Wall Papers, Games and other Staff. |
09-15-2004, 16:42 | #1 (permalink) |
No Life Poster Join Date: Dec 1999 Location: Sweden Age: 45
Member: 739 Status: Offline Thanks Meter: 0 | Need solution for siemens phones Without testpoint! any one know were i can find it ? /Gsmhq |
09-15-2004, 18:03 | #3 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Netherlands Age: 43
Member: 60442 Status: Offline Thanks Meter: 6 | www.martech.pl that's the only software without testpoint |
09-15-2004, 19:59 | #4 (permalink) | |
Junior Member Join Date: Jan 2004 Age: 46
Member: 51223 Status: Offline Thanks Meter: 0 | Quote:
this solution doesnt for all fw. M55 fw11 and <, c60 fw23 and < -test point is cheaper and faster -java aplet is seafly and you need more time -but martech is best | |
09-15-2004, 20:10 | #5 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Germany Age: 37
Member: 41076 Status: Offline Thanks Meter: 53 | Martech can't unlock without testpoint! You ever need testpoint! But if you have a Martech II and testpoint adapters you only need to connect 2 needles to PCB! (It's like testpoint emulation! ) Siemens will not see it and you won't loose warranty! That is the best solution! |
09-16-2004, 20:34 | #6 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Bandung - West Java, Indonesia Age: 43
Member: 71273 Status: Offline Thanks Meter: 14 | @chris02 what is the abbreviation of test points ???, what should we do if siemens phone need test points (cut the lines or what ?) can you send me the picture how to do / make the test points ??? thanks |
09-16-2004, 23:26 | #7 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 45
Member: 78421 Status: Offline Thanks Meter: 987 | Hello! Many people used to name "testpoints" - everything what is connected with T9 ball of older PMB main CPU of siemens x5x x60. this pin during reset of CPU shows what memory will be choosen for getting code for CPU. if this pin is on low state -> GND (0), CPU starts from main boot ROM, if state on pin is HIGH (1) - CPU reads code from external memory (flash in this case in phone). Inside flash there is start code - named "BootCore" (which allows to run registered bootloaders only - and allow crypted flashing with special siemens files). If somebody want to run own code (we want -> to do something with phone) - we have to put this pin to low state (GND) because internal boot ROM doesn't have this limitation, and our bootloaders can be run without problems. It's the reason why ppl connect T9 pin to GND (in older phones), and cut tracks (to make low state on this pin). ----------------------- Currently for new x55, x60 phones there are only one method for T9 pin -> cutting tracks. It's not good method, because it's very easy to damage phone. ----------------------- MARTECH Team made alternative method named: Martech BOX II + testpoint adapters. and alternative meanings of "testpoint" word. This method allows to access phone using easy - real "testpoint" - so only connecting special connectors to points on PCB. This method doesn't need any cuts! just connect easy points and access phone. ----------------------- Regards! |
09-19-2004, 12:47 | #9 (permalink) | |
No Life Poster Join Date: Oct 1999 Age: 48
Member: 4201 Status: Offline Thanks Meter: 6 | Quote:
Yes friend, but Martech talk here about cut hardware, or with martech 2+ special adaptor`s no need to make this. best regards, Irinel | |
NEED HELP ABOUT Nokia BB5 Without TesTpoints Add-On For MT Box | abdijaamac | MT-BOX | 1 | 11-29-2008 14:44 |
New Solution for Unlocking M55 v11 phones without testpoint! | 0xFEDF | E-Gold Based Phones | 125 | 03-20-2006 20:02 |
Need unlock solution New SE K608i without Testpoint! | to_deal_with | Wanted Products | 3 | 11-17-2005 15:06 |
any solution for CF62 with/without testpoint? | fuzionGSM | S-Gold Based Phones | 18 | 10-19-2004 12:45 |
Siemens Unlocker without testpoint (GERMAN Version) | HONGXING | E-Gold Based Phones | 5 | 09-05-2003 19:46 |
