Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq RingTones and WallPapers
Siemens-Benq RingTones and WallPapers NO Unlocking or Flashing threads here, this section for RingTones, Wall Papers, Games and other Staff.
Old 08-29-2005, 00:00   #1 (permalink)
Inovator's Avatar
Member: 144433
Thanks Meter: 49
Question Connection issue with SST 5.31
I have following problem;
I'm running SST 5.31 cracker, nad whe I connect any Siemens phon, try to establish connection, SST recognises that I click the red button, says; Enterin service mode or similar (depends on mobile type) and nothing happens. My CX65 turn in service mode, but it stays like that doing nothing. I tried with 3 different cables, 2 COM, and 1 USB, with 7 different mobile phone, from x35 to x65...same issue...what could be the problem?
TNX
Old 08-29-2005, 13:34   #2 (permalink)
ednacell's Avatar
Member: 76978
Thanks Meter: 15
TNX
Reinstall the 5.31 http://people.itu.int/~emartine/SST5.htm,,
If the sst program shows a blank com selection you will need to reinstall your window systerm.
Old 08-29-2005, 22:16   #3 (permalink)
Inovator's Avatar
Member: 144433
Thanks Meter: 49
I reinstalled it several times....
I manage to read x45 phones, but x65 phones don't work.
Phone goes in service mode, and nothing happens.
I tried to downgrade soft version on phones, but the same thing is happening.
what am I doing wrong?
Old 08-29-2005, 22:26   #4 (permalink)
dress2kill's Avatar
Member: 104694
Thanks Meter: 4
you need more power in the cable you use befor it can work i had the same problem but buy a com cable with 9volt battery test point it work perfekt like the one for samsung d500 try it... there is nothing wrong with sst
Old 08-30-2005, 00:05   #5 (permalink)
Inovator's Avatar
Member: 144433
Thanks Meter: 49
that could be it, but interesting, I never had any problems like that with V-klay, freia, or similar software, I'm wondering why is SST so special
Old 09-01-2005, 05:12   #6 (permalink)
Crazy Poster
Member: 169552
hi all
i have sst 5.32 but i can,t flash x65 that ver is up 33
plz help me
Old 09-01-2005, 10:19   #7 (permalink)
Member: 45985
Thanks Meter: 96
@ Inovator:
You can use it as it is,
just wait for ~2 minutes after you have reached test mode and then power off your phone.
After that press power on shortly and youŽll have it done,your phone will be unlocked(confirmed from program)
Wbr gjurobrod
Old 09-02-2005, 10:34   #8 (permalink)
Muneer Ahmed's Avatar
Member: 60500
Thanks Meter: 2
sst 5.31 iis not good for any fone i had it n it gave me many problems sometime it make the fone dead n some time by unlocking it gives wrong software sst 5.20 is the best crack software do not use sst 5.31
Old 10-02-2005, 01:42   #9 (permalink)
Member: 186149
Thanks Meter: 13
Hi, All......... I use 5.32
Press unlock, the phone should go into Service mode. The software in the bottom left corner should display: Service mode and then reading date or something wait until it says power on phone. At this stage power off the phone and back on again by the button. The software in the bottom left corner then says unlocking phone and then phone unlocked!
The above procedure works 100% for me!
Thanks
Old 10-03-2005, 00:14   #10 (permalink)
Inovator's Avatar
Member: 144433
Thanks Meter: 49
yes, thats correct procedure, I did it also by short connecting pins 3 and for inside the phone
SST 5.31 - 5.38 :stopping or hanging ciropizza S-Gold Based Phones 0 07-13-2005 09:24
C65 dead after unlocking with sst 5.31 rachelyna S-Gold Based Phones 9 05-05-2005 17:08
CXT70 Unlocked successfully with SST 5.31 cracked... byteforce S-Gold Based Phones 0 04-09-2005 11:23
SST 5.31 OR 5.32 ??? Download bendit S-Gold Based Phones 4 02-01-2005 23:31
do i need to make a test point on a65 with sst 5.31 crisrad E-Gold Based Phones 3 12-23-2004 22:05
Page generated in 0.23698 seconds with 9 queries
