02-11-2018, 18:07 | #1 (permalink) |
No Life Poster Join Date: Dec 2011 Location: Dubai, Africa, BD , China
Member: 1703977 Status: Offline Thanks Meter: 1,306 | Inferno tool activation ( 2 years ) only for promotion Service Name: INFERNO TOOL ACTIVATION ( 2 YEARS ) ONLY FOR PROMOTION DURING 2018.02.09 ~ 2018.02.27 1-Please ask your Client to “Download” & “Install” & “Run” latest ver of Volcano Software from support area 1.1 Here is link for Download latest ver (GPGIndustries - The #1 Cable and Hardware used around the world) 1.2Please make sure your client download correct software for their respected Device. For example if he have “Dongle” then he have to download “Inferno software for Inferno key” same like if he have “VolcanoBox” then he have to download “Inferno software for VolcanoBox” 2-After run 2.1 IF your client’s Inferno software is working then ask him to send you Complete serial which can be found Button of the software ****Serial Number starting from “608” is of VolcanoBox**** ****Serial Number starting from “308” is of Inferno key**** After “-“ 4 or 5 digits are Activation code. For example.. please check the picture It have Serial number 608000004 & 004n is activation code (activation code is in case-sensitive) 2.2 If your client’s inferno is not working ( Expired ) & giving this kind of error Then ask him to give you lock code and activation code. Please pay attention on lockCode: 6080000041005. Last 4 number is error code 1005 means client’s infernoKey or Volcanobox has been expired. ****Serial Number starting from “608” is of VolcanoBox**** ****Serial Number starting from “308” is of Inferno key**** 2.3 when you will active inferno Software for “Inferno Key” or “VolcanoBox” from “Serial numbers” you don’t have to write complete error code. You just write “608xxxxxx for volcanobox” and “308xxxxxx for inferno key” 3-Now you have serials and activation code for activation. Please have a look how you could active 3.1-Activation from Expired key (which show serial number with error code) From VolcanoBox (lockcode: 608XXXXXX1005 Activation Code: XXXXX) From InfernoKey (lockcode: 308XXXXXX1005 Activation code: XXXXX) 3.2-Type serial number 608XXXXXX (for activation don’t type “1005” from error code) in “Dongle ID” And type “Activation code” in “Active Code” 3.3-IF you type Serial number & Activation code for “VolcanoBox” then click on “Activation volcanobox” If you type Serial number & Activation code for “Infernokey” then click on “Activation Dongle” Your Activation will be done More Dateless Our Support Section Best Regards, www.codesunlocker.com sonork: 100.1590377 skype: Rayhan0111* whats’app/wechat/viber/imo 008613825015464 |
