Risanserver Best Online Unlocking Terminal 2014 |
10-20-2016, 21:21 | #1 (permalink) |
No Life Poster Join Date: Aug 2012 Location: Bamako Mali
Member: 1803689 Status: Offline Sonork: 100.1659873 Thanks Meter: 154 | Inferno activation problem for volcano box Dear damosco Your Order For Inferno Tool Activation for Volcano Box Has Processing failure . Reason : Job Data: SERIAL_NUMBER : 703-676-133 Active Code : 0rcx Quantity : 1 Result : Serial is wrong You Have Not Only Today But Also Tomorrow Best Regards RisanServer Team. But SERIAL is good see VOLCANO log Volcano Updated: 2015-9-30 Connecting... Connection successful,connected state! Version: V3.8 SN:703-676-133 Port:COM3 After format or Flash you have to press & hold power button for at least 1.30 mins. Note for win7 users : Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'. After that the spd drivers will have the ability to be loaded. Available Ports:COM1 COM3 >>Current Port:COM3 Please need help very urgent thank |
10-21-2016, 06:13 | #2 (permalink) |
Product Supporter Join Date: Jan 2011 Age: 34
Member: 1496414 Status: Offline Thanks Meter: 372 | VolcanoBox**** Serial Number starting from “608xxxxxx” Inferno key**** Serial Number starting from “308xxxxxx” After “-“ 4 or 5 digits are Activation code Your Serial Is Wrong Check And Re Order |
The Following User Says Thank You to Risan Supporter For This Useful Post: |
10-21-2016, 06:22 | #3 (permalink) |
No Life Poster Join Date: May 2013 Location: TkinterPy,Hex Cal,Ext2,Ext4,
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | Hi For more easy look bellow screenshots of How to find INFERNO tool serial and activation code EXAMPLE For Volcano box For INFERNO dongle Find it correct serial and activation code and sent to support for activation.Thank BR. FeeFi |
The Following 2 Users Say Thank You to ij_cell For This Useful Post: |
10-21-2016, 08:41 | #4 (permalink) |
Member: 1803689 Status: Offline Sonork: 100.1659873 Thanks Meter: 154 | Thank boss but my trial expired and when i launch inferno soft i can see: Your inferno activation has now expired. Kindly contact your resseler for renewal. (LockCode:6080017801005 ActivationCode:0rcx) |
