12-05-2013, 22:36 | #1 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2079234 Status: Offline Thanks Meter: 5 | Flashed LG LS970 & LS980 3G Connection Problem |
12-06-2013, 20:47 | #2 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: Los Angeles, CA
Member: 1081371 Status: Offline Thanks Meter: 720 | Quote:
Make sure that you have all your ITEMS stick ... i had couple of problems with this also ... i just make sure everything stick ... | |
12-11-2013, 16:30 | #3 (permalink) |
Member: 2079234 Status: Offline Thanks Meter: 5 | Hello. Thanks for your reply. So I got the 3G working but with some very minor problems... First the only way the 3G data will work is if you turn the mobile data OFF-ON about 4 to 5 times... Is this how this phone works after you flash it? Because honestly, it sücks. The second problem I have is the Hands-Free Activation will not go away. I pops up all the time. So besides those 2 problems, I successfully got the 3G working. But these problems make me want to throw this phone against the wall. I'm wondering kind sir, did you run into these problems as well? And did you find a solution for them? Thanks so much for your help, look forward to your reply. |
12-13-2013, 18:11 | #4 (permalink) |
Member: 2084065 Status: Offline Thanks Meter: 0 | Hey I'm new here, but i was having the same problems. This worked for me. Hope it works for you. Make sure all the evdo settings are sticking (nv-items in my case). I also enabled two profiles and set to PrefMobileIP. Then for the sprint lg ls980(4.2.2) dial 5589#*980# hit send. Then enter msl. Look for "data", in there look for "PPP". Then "carrier type" (is set to Sprint) change to "undetermined". Then reboot! |
12-14-2013, 22:01 | #5 (permalink) |
Member: 2079234 Status: Offline Thanks Meter: 5 | That's interesting. Thanks for the reply. I'm going to be honest. I gave up on this phone and got the Verizon LG G2. It flashes with absolutely no problems. Thanks for helping me out. If I have a customer in the future that needs the Sprint LG G2 flashed I will take your advice. But the good thing is, a lot of information about this phone is here for future people that run into these problems. Take care and Good Luck. |
02-27-2014, 20:30 | #7 (permalink) |
Junior Member Join Date: Feb 2014
Member: 2137508 Status: Offline Thanks Meter: 0 | anyone know what free programs can be used to flash the Sprint LS980? OP you mentioned that you were able to do it, but I'm assuming you used the paid version of CDMA workshop? Last edited by Pluton; 02-27-2014 at 21:28. |
04-07-2014, 18:08 | #9 (permalink) |
Insane Poster Join Date: Mar 2010
Member: 1268555 Status: Offline Thanks Meter: 2 | I have a Sprint LG LS970 I'm trying to get on Page Plus. I have everything, but the web. I did a master reset, ##786# and ##72786# I flashed both the LGE AndroidNet For Diagnostics Port and LGE AndroidNet USB Serial Port I added a "DMU" folder and copied the "10key" in there I used 60008, 60007, and 53247.prl I wrote them Universal NOT LG I changed the EVDO Rev: Revision A protocols with MFPA I added a profile and both profiles are enabled I changed the R. Interval: 2000ms and M.IP Beh: MobileIP I don't know what else to do. Any help would be greatly appreciated |
04-08-2014, 15:03 | #10 (permalink) |
Member: 2079234 Status: Offline Thanks Meter: 5 | Hello. The LS970 is a douchebag phone. Honestly I was only able to get solid 1x from this phone. And I got solid 1x from just flashing the Serial port only. When I messed with the diagnostic port the internet starts acting retarded. There are just some phones that don't like to flash right. Hopefully some other people on this forum can chime in but I have no clue how to get solid 3g on your phone. Good luck. |
05-11-2014, 11:54 | #11 (permalink) |
Junior Member Join Date: May 2014
Member: 2184227 Status: Offline Thanks Meter: 0 | hello, i im using lg l2 sprint version unlocked for both cdma and gsm. suddenly data on cdma has stopped working. so i flashed with ZV8 stock firmware, rooted and unlocked. GSM everything is working fine. i changed ruim config to ruim only. in PPP settings i changed to undetermined. voice on cdma is working but data is not working. Pls somebody help me to fix this issue..... Last edited by Pluton; 05-11-2014 at 20:04. |
05-24-2014, 21:23 | #12 (permalink) |
Insane Poster Join Date: Feb 2014 Location: Leesburg,FL
Member: 2138194 Status: Offline Thanks Meter: 2 | Ran into the same issue while attempting to flash it to another carrier other than Pageplus. I spent countless hours and found out nothing new. Evenually my customer just had to accept that 3g data wasn't going to be an option only 1x. |
