Go Back   GSM-Forum > Product Support Sections > IMEI or online Server Products > CDMA Workshop
Old 12-31-2012, 16:11   #1 (permalink)
ARAB GSM's Avatar
Member: 180675
Sonork: 100.111161 GSM GURU
How to connect galaxy stellar SGH-I200 in diag mode
How to connect galaxy stellar SGH-I200 in diag mode.to be able to work with workshop
software COM PORT only detect COM 17 SAMSUNG MOBILE USB MODEM when you check on ports.
Thank you
Tested all method inside Help file but no success
Old 01-06-2013, 07:15   #2 (permalink)
Member: 1004711
This is how I got mine to connect.. via the hidden menu. I'm still stuck tho... I can't find the security code to unlock the MEID. it's 16 digits and without it, I can't write or Repair the MEID. But.. do this to access the hidden menu and put your phone in the correct mode. VERY IMPORTANT: open your device manager in windows and look down at coms/ports to find which com port your Galaxy Stellar is connected.. don't pay attention to the other locations in Device Manager, just Coms/Ports.
You'll use that port number to connect to your CDMA workshop when you open it up.
So.. do this first to access hidden menu, then connect your phone via USB cable to your PC.. look in Device MGR and find coms ports and note the com port it's connected to. NEXT open CDMA workshop and connect via that com port number ONLY.
There are many things you can do without the 16 digit security code for the MEID but you'll need it to make changes to the MEID / IMEI.
If you find the security code for the Galaxy Stellar MEID unlocker, please share it with me. NOTE.. this is not the carrier lock.. there are 3 different locks on the Stellar, I believe.
If I can help you with anything else.. please let me know.
DO THIS FOR THE HIDDEN MENU on the Galaxy Stellar:
1.) Bring up the Dial Pad on the phone
2.) Press *#22745927
3.) When the "Enable/Disable Hidden Menu" comes up
tap where it says "Hidden Menu Disabled".
4.) Select "Enable" on the popup.
5.) Select "OK"
6.) Press the "Home" key to return to the home screen.
7.) Bring up the Dial Pad on the phone
8.) Press **87284 (USBUI)
9.) On "PhoneUtil" make sure "PDA" is selected.
10.) Select "Qualcomm USB Settings"
11.) Select "DM+MODEM+ADB"
12.) Select "OK"
NOTE: Don't forget to set it back when you're done.
Credit goes to the good folks over at XDA
The Following 2 Users Say Thank You to barefootdude For This Useful Post:
Old 01-06-2013, 09:26   #3 (permalink)
Pluton's Avatar
Member: 20073
barefootdude
Better use "Port:" button in CDMA Workshop. It is more easy way. It will show you all installed ports in your system.
The Following 3 Users Say Thank You to Pluton For This Useful Post:
Old 01-08-2013, 14:24   #4 (permalink)
ARAB GSM's Avatar
Member: 180675
Finaly i unlocked my phone,I used test button and it selected i920 and 16 digits security code was sent successfully
Phone is working 100% call and receive
Data is also working perfect.....
Thank you very much
100% solution
5.) Select "OK"
12.) Select "OK"
Log message: > SPC is correct. Device unlocked
The Following 2 Users Say Thank You to ARAB GSM For This Useful Post:
Old 01-08-2013, 15:40   #5 (permalink)
Member: 1004711
You were able to use the code for the i920 on the i200 stellar? that's great.. what is the security code? will you please copy it and paste it here? Thank you and glad I was able to help.
Old 01-09-2013, 09:32   #6 (permalink)
ARAB GSM's Avatar
Member: 180675
The test button send codes to phone automatically,you want see code only model will be shown in this activity.
Old 01-10-2013, 07:00   #7 (permalink)
Member: 1004711
you can click the READ button after you've sent the test and it accepts.. it should display what the code was since it's unlocked the phone will let you do about anything.
there are a few areas where you should be able to read it, if I'm not mistaken.. as long as it accepts the code when you TEST it.. it is then unlocked.
Page generated in 0.40080 seconds with 11 queries
