Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported IMEI calculator Sites or Software Products > CDMA Workshop
Old 03-20-2013, 18:08   #1 (permalink)
ARAB GSM's Avatar
Member: 180675
Sonork: 100.111161
Thanks Meter: 411
How to get this phone in DIAGNOSTIC MODE
Need ZTE X500 DIAG mode diag code
Old 03-21-2013, 17:32   #2 (permalink)
Member: 1881258
Thanks Meter: 2
try *983*87274# tap on diag then select, go to menu,settings, and depending on android version (2.3)go to applications then development and check usb debug (4.0) go to developer options then check usb debug
Old 03-25-2013, 12:30   #3 (permalink)
ARAB GSM's Avatar
Member: 180675
Sonork: 100.111161
Thanks Meter: 411
your code did not work for my phone,my friend also gave me this but no success ##33284* Access code 983324 but when i get into this page there is no diag in list of listed app.is there any way to get my phone into diag mode
Old 03-25-2013, 14:45   #4 (permalink)
Member: 879967
Thanks Meter: 28
*#06# - Show MEID
##36* - Switching server for FUMO update over the air (com.redbend.vdmc.VDMC_SETTING)
##276* - APN settings (android.settings.APN_SETTINGS)
##337* - carefull it erase data form SD card too Factory Reset Recovery Phone (com.ztemt.fdr.ENTRY_ACTION)
##744625* - Voice service option (com.ztemt.voice.os.setting.ENTRY_ACTION)
##7738* - Mobile Call-Air Interface Revision (com.ztemt.field.debug.7738.ENTRY_ACTION)
##3282* - Date Profile, Browser, EVDO settings (com.ztemt.field.debug.3282.ENTRY_ACTION)
##8378* - Some EVDO and other settings (com.ztemt.field.debug.8378.ENTRY_ACTION)
##4357* - Field Tst Mode (com.ztemt.fieldtestmode.ENTRY_ACTION)
##33284* access code 983324 - DEBUG EVDO Engineering, 1x Engineering, Data Status, Configuration, Memory, Bluetooth (com.ztemt.field.debug.33284.ENTRY_ACTION)
##2539* - Set akey
##626* subsidy code 333333 - Fast NAM programming: MDN, MIN, CDMA Home SID
##7764* - Full Service NAM Programming
*#1208888999# - InterVersion (com.ztemt.interversion.ENTRY_ACTION)
*#12088889999# - InterVersion Details (com.ztemt.interversiondetails.ENTRY_ACTION)
##23766* - Enable/Disable virtual CD-ROM with drivers (com.ztemt.cdrom.ENTRY_ACTION)
##386* or *#0000# - Enable modem mode (com.ztemt.modem.ENTRY_ACTION)
*#8605# - All Factory test (com.ztemt.factory.ENTRY_ACTION)
*#8604# - Factory test per item (com.ztemt.factorysinglemode.ENTRY_ACTION)
*#8615# - Advanced Factory test Bluetooth, Wifi, GPS(com.ztemt.advanced.ENTRY_ACTION)
*#8625# - (com.ztemt.debug.ENTRY_ACTION) - not work on my X500
##82* - MMS settings (com.android.qualcomm.cdma.nam.ENTRY_ACTION)
##77* - Proximity sensor Calibration (com.ztemt.pscalibration.ENTRY_ACTION)
Old 03-26-2013, 15:39   #5 (permalink)
ARAB GSM's Avatar
Member: 180675
Sonork: 100.111161
Thanks Meter: 411
Service not showing how can i manual program phone? phone says no service,i need diag mode and drivers any help?
Old 04-24-2017, 16:44   #6 (permalink)
Member: 2663255
for programing :
##626*
code : 333333
diag mode is already enable
you just need the right deriver you can download from here
download
install it in your pc - reboot
and you are good now.
Page generated in 0.22132 seconds with 7 queries
