06-10-2013, 10:51 | #1 (permalink) |
Major Poster Join Date: Apr 2013
Member: 1926710 Status: Offline Thanks Meter: 13 | Verizon/Sprint/USCellular S3/S4/Note 2 Diag Modes and 16 Digit Passwords I will update as needed, one of the phones updated to 4.1.2 the diag mode method changed, to early in the morning right now, I will update it later.... 16 Digit Passwords: USCC S3 2010031619780721 Verizon S3 2009031920090615 Sprint S3 01F2030F5F678FF9 or 2012112120131219 Sprint SPH-L710 (Galaxy S III) and SPH-L900 (Note 2) Open Dialer enter ##3424# When PhoneUtil Opens Select PDA Tap Qualacomm USB Setting Select DM+Modem+ADB Tap OK (Remember after flashing to return and put phone back to MTP+ADB) Verizon ]SPH-I535 (Galaxy S III) and SCH-I605 (Note 2) Open Dialer enter *#22745927 When Enable/Disable Menu comes up tap "Hidden Menu Disabled" Select "Enable" on Popup Press Home button Open Dialer Dial **87284 When PhoneUtil Opens Select PDA Tap Qualacomm USB Setting Select DM+Modem+ADB Tap OK (Remember after flashing to return and put phone back to MTP+ADB) USCellular SCH-R530 U (Galaxy S III) and SCH-R950 (Note 2) Open Dialer enter *#22745927 When Enable/Disable Menu comes up tap "Hidden Menu Disabled" Select "Enable" on Popup Press Home button Open Dialer Dial **87284 When PhoneUtil Opens Select PDA Tap Qualacomm USB Setting Select DM+Modem+ADB Tap OK (Remember after flashing to return and put phone back to MTP+ADB) Verizon SPH-I545 (Galaxy S4) Dial ##DMMODE# Tap On Sprint SPH-L720 (Galaxy S4) There are two options to dial for diag menu on this phone ##3424# and *#7284# One will ask for an SPC Code and One will Not Use the one that does not ask for SPC Code When PhoneUtil Opens Select PDA Tap Qualacomm USB Setting Select DM+Modem+ADB Tap OK (Remember after flashing to return and put phone back to MTP+ADB) |
The Following 3 Users Say Thank You to flasher32 For This Useful Post: |
06-10-2013, 23:51 | #3 (permalink) | |
Member: 1926710 Status: Offline Thanks Meter: 13 | Quote:
http://forum.xda-developers.com/show....php?t=2270191 Viper | |
The Following 2 Users Say Thank You to flasher32 For This Useful Post: |
06-11-2013, 21:11 | #4 (permalink) | |
Freak Poster Join Date: Oct 2010 Location: 32.7798° N, 96.8084° W
Member: 1430518 Status: Offline Thanks Meter: 25 | what if no qualcomm mode? Quote:
The Following User Says Thank You to Flux Capacitor For This Useful Post: |
07-14-2013, 03:02 | #9 (permalink) | |
Insane Poster Join Date: Mar 2013 Location: U.S.A.
Member: 1893099 Status: Offline Thanks Meter: 10 | US Cellular S4? Hi, I see that the US Cellular S4 method is missing... Does anyone know that one by chance? Quote:
07-14-2013, 11:41 | #10 (permalink) |
Member: 1926710 Status: Offline Thanks Meter: 13 | Try this apk. this will get you in diag mode..... Viper https://www.dropbox.com/s/2ln209o53t...honeUtilss.apk |
