03-01-2013, 03:39 | #32 (permalink) |
Junior Member Join Date: Jun 2008
Member: 798514 Status: Offline Thanks Meter: 0 | I have a sprint phone that took a 4.1.2 update and now the 16digit when dead.... I had to flash back to 4.1.1 to get it "fixed" to original. is that the same one or is there a method to extract those from the new firmware? |
03-05-2013, 14:28 | #35 (permalink) |
Junior Member Join Date: Feb 2009
Member: 967223 Status: Offline Thanks Meter: 0 | This is what I have, now what So I have R530U US Cellular and this is what I got so far 1. *#22745927 --ENABLE HIDDEN MENU GO TO STEP 2 (will let you enable hidden menu) 2. **87284 CLICK ON QUALCOM USB SETTINGS 3. Select CDMA Modem 4. Click Qualcomm USB Setting 5. CHECK DM+MODEM+ADB 6. Then Drivers load up & I open CDMA Workshop 7. Select the com number thats shown in device manage under ports 8. Click Connect then Read 9. Went to security TAB put in this 16digit pass 2010031619780721 clicked send & it worked said unlocked 10. Went to Universal, EFS Method under SPC with code 000000 clicked SPC > Send & it worked said unlocked ...now im lost what do I do next what info do i need to fill out where and do i need to the New carrier info from an active phone, old phone or call/talk with someone from boost mobile the new carrier?? |
03-07-2013, 23:41 | #36 (permalink) |
Insane Poster Join Date: Mar 2013 Location: stillboosted
Member: 1895702 Status: Offline Thanks Meter: 4 | Like Eng1neer said, I also have used the Samsung default (01F2030F5F678FF9) to unlock several of the Galaxy Note2's..Now this particular one I am working with says the password is incorrect... The only thing different is that its on this 4.1.2 software, I have tried the 2010031619780721 password, but it doesn't work. I also tried the "Test" feature and got "151 passwords were incorrect". I was afraid I'd have to roll back the software, but was trying desperately to find the correct 16 digit password to this new software...I've scoured the web though with no luck at all. |
03-10-2013, 06:12 | #39 (permalink) |
Member: 798514 Status: Offline Thanks Meter: 0 | in order to get things "back to normal" I had to roll back to 4.1.1 on both the note 2 and also on G3. There are stock flash files for both and it was done via oden.. did do a stock reset when I flashed it back.. but the 16 digit default worked again. |
07-19-2013, 07:04 | #45 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 307625 Status: Offline Thanks Meter: 25 | now metropcs are using 14 digit imei its kinda hard to unlock the sim or to repair imei either one its hard challenge for now,,,,,,,,,,,,,,but be for u do anything make sure u back up ur nv files............... |
