Go Back   GSM-Forum > Product Support Sections > IMEI or online Server Products > CDMA Workshop
Old 01-16-2013, 05:37   #1 (permalink)
Flux Capacitor's Avatar
Member: 1430518
samsung l710 diagnostic port
having trouble connecting to diag port= do *#7284# then *#9090# and then restart but only show serial port no diag-are there any other steps? -thanks
Old 01-16-2013, 18:58   #2 (permalink)
Member: 1430518
must have read wrong instructions although the *#7284# AND the *#9090# DID work-i have now done a hard reset and now neither of them work. the correct combination is: ##3424# (works)
Go to Menu, Settings, Applications, Development and check "USB Debugging"
Plug in USB Cable to Phone.
Bring up the dial pad and enter ##3424#
Select CDMA Modem
Select Qualcom USB Setting
Select DM + Modem + ADB
Select OK
Scan and Flash normally.
serial port is visible but cannot connect to it. anyone ever done one of these w success?
Old 01-17-2013, 16:33   #3 (permalink)
Member: 1430518
just flashed w stock firmware-still no diag port visible-i am trying to change spc to 000000 so i can flash to pageplus-????can be donw w/o diag port?
D:\SAMSUNG\L710VPALEN_L710SPRALEN_SPR\KIES_HOME_L7 10VPALEN_L710SPRALEN_618049_REV03_user_low_ship.ta r.md5
Old 01-17-2013, 17:15   #4 (permalink)
Member: 1430518
ok-time ran out customer picking up this morning.......had to use an online flashing service (htf do they connect?) everything works including data!.....
Old 01-18-2013, 16:47   #5 (permalink)
Pluton's Avatar
Member: 20073
So what was the problem with Diagnostic port?
Old 01-24-2013, 03:52   #6 (permalink)
Member: 92260
I got it connected with ADB debug OFF
##3424#
Select CDMA Modem
Select OK
Also a Micro-UART cable works too with a 500K resister between pins 5 and 6 (gnd)
To get the SPC first make sure you are not on v4.0.4 cuz there's a bug in it, higher or lower version is fine.
Then with ADB debug ON type ##3282# enter a bogus SPC like 000000
then in command prompt type:
adb shell getprop ril.MSL
Good luck!
BillA
Page generated in 0.28202 seconds with 10 queries
