06-09-2014, 17:16 | #1 (permalink) |
Insane Poster Join Date: Mar 2014
Member: 2146354 Status: Offline Thanks Meter: 21 | SM-N900P nam settings not sticking! Baseband: N900PVPUCNAB Last edited by Pluton; 06-10-2014 at 08:10. |
06-19-2014, 19:13 | #3 (permalink) |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | Put the phone in diag mode. Set up your COM ports in your flashing program(s) and get the SPC and security codes ready. Power off the phone. Pull the battery. Wait 10 seconds. Put it back in and boot the phone. Flash the phone as quickly as you can. Reboot. See if everything stuck. If it didn't, pull the battery again, wait 10 seconds, boot back up, and write whatever didn't stick. Apparently it seems that on the Note 3, there's some kind of protection that fights you while you're trying to program the phone manually. I've noticed that it only happens after the phone has been running for a while, like all of the NV items lock. On a boot though, they seem to be released. Bug? Maybe. That particular Kit Kat build is still write-able though and therefore possible. |
The Following User Says Thank You to ecs87 For This Useful Post: |
06-19-2014, 19:27 | #4 (permalink) |
Member: 2146354 Status: Offline Thanks Meter: 21 | thanks for all the support guys. I got it to work. all I did was write the settings with the phone in offline d and offline a mode and that did it. I used cdma workshop by the way |
01-09-2015, 17:54 | #6 (permalink) | |
Freak Poster Join Date: May 2014 Location: INDIA
Member: 2184652 Status: Offline Thanks Meter: 103 | Help me Bro if any solution u have Quote:
NAM is not Sticking, What Can i do now??? Baseband: N900PVPUCNAB Pls help me | |
01-09-2015, 20:23 | #7 (permalink) |
Insane Poster Join Date: Nov 2014 Location: Chicago,IL
Member: 2295165 Status: Offline Thanks Meter: 15 | this is what i do i send the pw and msl then i read the phones for the nams then i load the nam file then click write about 6 times then disconnect from phone then i connect to the phone send the pw and msl and press write 6 more times then i press read at the top next to disconnect button then send the pw then press write 6 more times then reboot phone when phones comes bk up connect to phone read the phone and now everything is in the phone |
01-10-2015, 16:54 | #8 (permalink) | |
No Life Poster Join Date: Jan 2003 Location: CDMA-WARE
Member: 20073 Status: Offline Thanks Meter: 250 | mrhunter13 Quote:
So, we added new option in Advanced settings "AutoModeOfflineD" in order to deactivate auto switching. This new option will be available in new upcoming version of CDMA Workshop. | |
01-11-2015, 02:28 | #9 (permalink) | |
Member: 2295165 Status: Offline Thanks Meter: 15 | Quote:
