Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported IMEI calculator Sites or Software Products > CDMA Workshop
Old 06-19-2014, 18:47   #1 (permalink)
Flux Capacitor's Avatar
Member: 1430518
Thanks Meter: 25
sprint l720 16 digit password 4.4.2 MSL wont change
using this 16 digit password= 2012112120131219 which works great and shows msl with no problem-but for some reason MSL does not change-have tried all methods = default, direct eeprom etc. but msl does not change. has anyone else had a problem in this area? -thanks
Old 06-19-2014, 19:16   #2 (permalink)
Member: 2076039
Thanks Meter: 648
If you're just trying to find the MSL code just use the app that gets it for you. If you HAVE TO change the SPC (not too sure why you'd HAVE TO...) send the AT (or was it GOBI?) commands through the terminal to the phone. The commands you're going to have to send are the ones that were made public to reset the SPC to 000000 for the S3.
Old 06-19-2014, 21:13   #3 (permalink)
Member: 1430518
Thanks Meter: 25
as stated before-i can read spc/msl- the 16 digit password brings it up. msl reset script is also not working. in the past it was a modem downgrade needed so i am thinking it will be a modem change issue-but would like to hear from someone who has experienced this firsthand.
Old 07-01-2014, 19:06   #4 (permalink)
jusmejose's Avatar
Member: 1081371
Thanks Meter: 720
Downgrade the modem to MDC , Use script to change 000000 after flash back original modem and problem solved ...
Old 07-15-2014, 00:58   #5 (permalink)
Member: 1926710
Thanks Meter: 13
But why even change it? Makes no sense at all.
Go figure.
Viper
Old 09-02-2014, 22:11   #6 (permalink)
Member: 1430518
Thanks Meter: 25
when flashing a sprint phone to pageplus (verizon) the msl needs to be changed to 000000-pure and simple.
Go figure.
Viper
Old 09-02-2014, 23:51   #7 (permalink)
Member: 1926710
Thanks Meter: 13
LOL,
I can tell you have not been doing this long,
Plain and Simple no it does not need to be changed to flash or work on Page Plus....
Maybe you need to check your facts before typing such a response. RThe MSL does not need changed at all to work period (Plain and SIMPLE)
Viper
Old 09-10-2014, 23:47   #8 (permalink)
jusmejose's Avatar
Member: 1081371
Thanks Meter: 720
You don't need to change it actually .... Unless your going to OTA that's all.. other than that you don't need to ....
Old 12-14-2017, 23:50   #9 (permalink)
Member: 2777900
Looking for tips on how to get the SPC and/or MSL code from a Netgear 341U USB data stick. Any Netgear or Sierra Wireless
Page generated in 0.16845 seconds with 9 queries
