Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported IMEI calculator Sites or Software Products > CDMA Workshop
Old 01-23-2013, 17:36   #1 (permalink)
Pluton's Avatar
Member: 20073
Thanks Meter: 250
Arrow Successfully unlocked, flashed, repaired phones/modems/etc with using CDMA Workshop..
Put your experience, steps or maybe an YouTube
video with specific models here...
The Following User Says Thank You to Pluton For This Useful Post:
Old 01-24-2013, 13:05   #2 (permalink)
ARAB GSM's Avatar
Member: 180675
Sonork: 100.111161
Thanks Meter: 411
Unlock HTC EVO 4G Sprint With CDMA Workshop
1-You first need original version of CDMA WORKSHOP.
2-Setup necessary drivers for your htc phone.. Android Diag driver
3=Take phone to diag mode buy using ##3424# on phone and it will send phone to diag mode (You can find many of this codes at the help menu of your workshop.
4-Connect phone to pc via usb New hardware will successfully install if only you installed the right HTC diag driver on your pc
5-Click on port at the left top corner of workshop and select htc diag com port from list then connect phone.
6- Press on read button on workshop and phone information will be readed
7- Go to security TAP then test and send 16 digit code to phone.
8- Random select will be sent to phone and after this send spc and your phone is unlocked
9- Get your service provider details and use MAIN TAP to program phone to your specific network provider.
Thank you for opening this thread,you can edit my post if there is any misunderstanding.
Welcome every body
Thank you Pluton
[email protected]
[email protected]
The Following 2 Users Say Thank You to ARAB GSM For This Useful Post:
Old 02-05-2013, 07:07   #3 (permalink)
Member: 1756891
Thanks Meter: 3
Welcome every body
Thank you Pluton
[email protected]
[email protected]
there are some cases when cdma ws doesnt read the spc off htc devices in such a case insert following terminal code then go back to security tab and read spc
Old 02-05-2013, 15:09   #4 (permalink)
Pluton's Avatar
Member: 20073
Thanks Meter: 250
"HTC method" in CDMA Workshop will work for most of Windows Mobile and Android-based HTC models to read SPC. For MDM9600 part of newest LTE HTC models (Thunderbolt, Rezound and future) you need to use "Universal, EFS_RAW" method in CDMA Workshop to read SPC.
Old 02-09-2013, 08:15   #5 (permalink)
Member: 1716203
Sonork: 100.111161
Thanks Meter: 17
Samsung u450 successfully unlocked 3 pcs
[IMG] Uploaded with ImageShack.us[/IMG]
Br,
High Tech Solutions
[email protected] [email protected]
Old 02-14-2013, 18:13   #6 (permalink)
ARAB GSM's Avatar
Member: 180675
Sonork: 100.111161
Thanks Meter: 411
Samsung M520 Unlocked with WS
[IMG] ImageShack.us[/IMG]
Thank you WS Team
High Tech Solutions
Old 02-21-2013, 12:02   #7 (permalink)
ARAB GSM's Avatar
Member: 180675
Sonork: 100.111161
Thanks Meter: 411
Samsung SCH R631 Cricket Messager Touch Unlocked
[IMG][/IMG]
Best Regards
High Tech Solutions
Old 02-22-2013, 17:00   #8 (permalink)
ARAB GSM's Avatar
Member: 180675
Sonork: 100.111161
Thanks Meter: 411
Cal Comp A300 successfully Unlocked with WS
Reading Full SDRAM memory region:
Done.
SPC      (Service Provider Code)                 =     136972
FSC      (Field Service Code)                      =     333333
OTKSL  (One Time Keypad Subsidy Lock)      =     Inactive
Universal RAM_3A Method works perfect to get 411 SPC codes but first code was accepted manually
Big thanks goes to tigran80 for supporting me.
Best Regards
High Tech Solutions
The Following User Says Thank You to ARAB GSM For This Useful Post:
Old 02-22-2013, 17:26   #9 (permalink)
Pluton's Avatar
Member: 20073
Thanks Meter: 250
ARAB GSM
In this case, the best way is to save gotten dump of memory to your hard disk and then load it into the Keyboard Codes searcher (see Menu - Tools) with option "Parsing EFS dumps"
This option will extract all usefull information, including SPC, EVDO logins/passwords, etc. You do not need to Test all 411 found probable SPC codes.
Old 02-23-2013, 18:09   #10 (permalink)
ARAB GSM's Avatar
Member: 180675
Sonork: 100.111161
Thanks Meter: 411
samsung-galaxy-stellar-sch-i200 Unlocked with WS
[IMG][/IMG]
Use the steps below to enable diag
1.) Bring up the Dial Pad on the phone
2.) Press *#22745927
3.) When the "Enable/Disable Hidden Menu" comes up
tap where it says "Hidden Menu Disabled".
4.) Select "Enable" on the popup.
5.) Select "OK"
6.) Press the "Home" key to return to the home screen.
7.) Bring up the Dial Pad on the phone
8.) Press **87284 (USBUI)
9.) On "PhoneUtil" make sure "PDA" is selected.
10.) Select "Qualcomm USB Settings"
11.) Select "DM+MODEM+ADB"
12.) Select "OK"
Log message: > SPC is correct. Device unlocked
Best Regards
High Tech Solutions
[email protected]
Thanks to tigran80
Old 02-25-2013, 20:07   #11 (permalink)
Member: 1726182
Nice tread ön CDMA.Treadowner pls can u help me UNLOCK A MOTOROLA iDEN PHONE: MOTOROLA {CLUTCH} i465 please?if yes I will send details later.am anticipatin a positive responce,i wil b observin d tread.tnkx.
The Following User Says Thank You to Crakah7 For This Useful Post:
Old 03-12-2013, 19:08   #12 (permalink)
ARAB GSM's Avatar
Member: 180675
Sonork: 100.111161
Thanks Meter: 411
Galaxy S2 i500 Unlocked with WS
[IMG]
[/IMG]
Regards
High Tech Solutions
Old 04-23-2013, 11:38   #13 (permalink)
ARAB GSM's Avatar
Member: 180675
Sonork: 100.111161
Thanks Meter: 411
Sanyo Zio made by Kyocera Unlocked
High Tech
Old 04-26-2013, 16:36   #14 (permalink)
Member: 1527378
does it support for motorola admiral [from spint]
please answer this...
i want to know before buying i dont wont lose my money
Old 05-03-2013, 20:57   #15 (permalink)
Member: 1928138
Successfully Flashed a Sprint HTC Evo 4G to Metro Pcs. Thanks to everyone
The Following User Says Thank You to ifonerepair For This Useful Post:
Page generated in 0.31852 seconds with 9 queries
