03-20-2013, 18:08 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: West Africa Ghana Age: 15
Member: 180675 Status: Offline Sonork: 100.111161 Thanks Meter: 411 | How to get this phone in DIAGNOSTIC MODE How to get this phone in DIAGNOSTIC MODE |
03-21-2013, 17:32 | #2 (permalink) |
Junior Member Join Date: Feb 2013
Member: 1881258 Status: Offline Thanks Meter: 2 | try *983*87274# tap on diag then select, go to menu,settings, and depending on android version (2.3)go to applications then development and check usb debug (4.0) go to developer options then check usb debug |
03-25-2013, 12:30 | #3 (permalink) |
Member: 180675 Status: Offline Sonork: 100.111161 Thanks Meter: 411 | your code did not work for my phone,my friend also gave me this but no success ##33284* Access code 983324 but when i get into this page there is no diag in list of listed app.is there any way to get my phone into diag mode |
03-25-2013, 14:45 | #4 (permalink) |
Freak Poster Join Date: Oct 2008
Member: 879967 Status: Offline Thanks Meter: 33 | *#06# - Show MEID ##36* - Switching server for FUMO update over the air (com.redbend.vdmc.VDMC_SETTING) ##276* - APN settings (android.settings.APN_SETTINGS) ##337* - carefull it erase data form SD card too Factory Reset Recovery Phone (com.ztemt.fdr.ENTRY_ACTION) ##744625* - Voice service option (com.ztemt.voice.os.setting.ENTRY_ACTION) ##7738* - Mobile Call-Air Interface Revision (com.ztemt.field.debug.7738.ENTRY_ACTION) ##3282* - Date Profile, Browser, EVDO settings (com.ztemt.field.debug.3282.ENTRY_ACTION) ##8378* - Some EVDO and other settings (com.ztemt.field.debug.8378.ENTRY_ACTION) ##4357* - Field Tst Mode (com.ztemt.fieldtestmode.ENTRY_ACTION) ##33284* access code 983324 - DEBUG EVDO Engineering, 1x Engineering, Data Status, Configuration, Memory, Bluetooth (com.ztemt.field.debug.33284.ENTRY_ACTION) ##2539* - Set akey ##626* subsidy code 333333 - Fast NAM programming: MDN, MIN, CDMA Home SID ##7764* - Full Service NAM Programming *#1208888999# - InterVersion (com.ztemt.interversion.ENTRY_ACTION) *#12088889999# - InterVersion Details (com.ztemt.interversiondetails.ENTRY_ACTION) ##23766* - Enable/Disable virtual CD-ROM with drivers (com.ztemt.cdrom.ENTRY_ACTION) ##386* or *#0000# - Enable modem mode (com.ztemt.modem.ENTRY_ACTION) *#8605# - All Factory test (com.ztemt.factory.ENTRY_ACTION) *#8604# - Factory test per item (com.ztemt.factorysinglemode.ENTRY_ACTION) *#8615# - Advanced Factory test Bluetooth, Wifi, GPS(com.ztemt.advanced.ENTRY_ACTION) *#8625# - (com.ztemt.debug.ENTRY_ACTION) - not work on my X500 ##82* - MMS settings (com.android.qualcomm.cdma.nam.ENTRY_ACTION) ##77* - Proximity sensor Calibration (com.ztemt.pscalibration.ENTRY_ACTION) |
04-24-2017, 16:44 | #6 (permalink) |
Junior Member Join Date: Dec 2016 Location: yemen
Member: 2663255 Status: Offline Thanks Meter: 0 | for programing : ##626* code : 333333 ---------------------- diag mode is already enable you just need the right deriver you can download from here download install it in your pc - reboot and you are good now. |
