Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
05-31-2019, 07:48 | #1 (permalink) |
Insane Poster Join Date: Oct 2005
Member: 191947 Status: Offline Thanks Meter: 10 | A105F can not flash combination file I recompiled combination file without PIT file and tried to flash again, this time flash stops with error when trying to flash boot.img (Bootloader does not allow to flash custom files). I can reflash original stock firmware without any problem.. Stock firmware allows me to set OEM unlock ON but it seems that bootloader is still locked Any solution for this problem? |
05-31-2019, 11:52 | #2 (permalink) | |
Freak Poster Join Date: Jan 2018
Member: 2796172 Status: Offline Thanks Meter: 42 | The problem has been known for a while, it happens to all the S10, and phones that end X05. That's what I've found on another forum. Haven't tried it yet, but I am pretty sure it might void the warranty Quote:
05-31-2019, 14:01 | #3 (permalink) |
Freak Poster Join Date: Jun 2016 Location: Home Age: 27
Member: 2583091 Status: Offline Thanks Meter: 413 | The error is happens because the RMM STATE is set to PRENORMAL, so first try to disable RMM STATE. |
The Following User Says Thank You to Feiselski For This Useful Post: |
06-27-2019, 12:45 | #7 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Djazair
Member: 111121 Status: Offline Sonork: 100.99340 : CrKdz13 Thanks Meter: 487 | i have the same issue , and can't remove FRP , im on U2 , with JUNE security patch , the "Remove SIM card" trick not work , neither "SIM with PIN trick" , and other idea ? WBR |
The Following User Says Thank You to CrKdz13 For This Useful Post: |
