Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
06-08-2019, 12:22 | #1 (permalink) |
No Life Poster Join Date: Mar 2018 Location: Future.... ✌️
Member: 2825953 Status: Offline Thanks Meter: 246 | A205f can't flash combination please get the approval to use factory binaries (pit) PLEASE GET THE APPROVAL TO USE FACTORY BINARIES (PIT) |
The Following User Says Thank You to -=P.F.U=- For This Useful Post: |
06-08-2019, 13:06 | #2 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,108 | Hi, You can try this method. How to unlock Bootloader, Galaxy A20 (SM-A205F) with Download Mode. Unlock Bootloader : In Download Mode you see the long press Vol Up option to enter Device Unlock Mode. Unlock the bootloader ( that will wipe your device so be sure to backup of your data ) Read description on the Unlock Bootloader screen then use Volume UP to select “YES” to confirm and “No” to cancel unlock bootloader and restart the phone. After Bootloader unlock, the phone will reboot and make sure the phone connected to the internet or triggers KG State / RMM State Prenormal. Setup the phone without google account etc. The Bootloader are unlocked!
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
06-08-2019, 23:57 | #3 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
The Following User Says Thank You to CHANDARAKK For This Useful Post: |
06-17-2019, 17:07 | #6 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,108 | Hi, You can download Patch Odin for your requirement from the links are below. Odin3 v3.13.1_3B_PatcheD.zip Odin3 v3.13.1_3B_PatcheD.exe
The Following 6 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
07-18-2019, 14:15 | #9 (permalink) |
Freak Poster Join Date: May 2007 Location: portugal
Member: 515940 Status: Online Thanks Meter: 29 | Here also same problem with Samsung A505fn combination firmware here please get the approval to use factory binaries (pit) |
The Following User Says Thank You to khudda1234 For This Useful Post: |
08-14-2019, 12:26 | #10 (permalink) | |
Junior Member Join Date: Aug 2013 Location: Moldova
Member: 2012212 Status: Offline Thanks Meter: 3 | I can not unlock SM-A505FN Quote:
Reading phone info... Model: SM-A505FN Android version: 9 PDA version: A505FNXXU2ASG3 CSC version: A505FNOXM2ASG3 Phone version: A505FXXU2ASG2 Product code: SM-A505FZOSTPH CSC country code: portugal CSC sales code: TPH Phone SN: XXXXXXXXXXX IMEI: XXXXXXXXXXXXXX HW version: MP0.400 RF cal date: 20190427 Chip name: EXYNOS9610 Modem board: SHANNON337 Security patch: 2019-06-01 Boot Warranty bit: 0 SIM State: ABSENT,REGIONAL_LOCKED Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... modem not supported Searching server... OK Checking available files... not found compatible file Try downgrade modem if possible Хотел разблокировать GSM. Но Z3X не может этого сделать, выдает сообщение о понижении версии модема. Не могу этого сделать, потому как загрузчик версии 2. И прошить Combination смартфон тоже не дает, пишет необходимо получить разрешения. Уже пробовал и PIT считывать с телефона как пишут на форумах, и включал OEM Unlock и сейчас уже разблокировал загрузчик, статус в загрузчике после этого был KG STATE: Prenormal. Пункт OEM Unlock пропал в настройках, сделал так чтобы отображался, статус поменялся на KG STATE: Checked, но ни в одном из случаем так и не смог прошить COMBINATION c загрузчиком версии V2. Как можно решить данный вопрос? I wanted to unlock GSM. But Z3X cannot do this, it displays a message about downgrading the modem. I can not do this, because the loader is version 2. And the smartphone also does not give the Combination flash, it says you need to get permission. Already tried and read the PIT from the phone as they say on the forums, and turned on OEM Unlock and now unlocked the bootloader, the status in the bootloader after that was KG STATE: Prenormal. The OEM Unlock item disappeared in the settings, made it appear, the status changed to KG STATE: Checked, but in no case was it able to flash COMBINATION with the bootloader version V2. How can this problem be resolved? | |
The Following 3 Users Say Thank You to CJstyle For This Useful Post: |
08-14-2019, 12:41 | #11 (permalink) |
No Life Poster Join Date: Oct 2017 Location: on google.com
Member: 2771307 Status: Offline Thanks Meter: 772 | New security in Samsung phone with July 2019 patch no solution now with any phone that got this security, need wait for an update from box programer. The same case is with all new phone like S10, S10+, S10e and any other. |
The Following User Says Thank You to IMEI_info For This Useful Post: |
08-23-2019, 16:41 | #13 (permalink) |
Banned Join Date: Dec 2018 Location: India
Member: 2885667 Status: Offline Thanks Meter: 39 | According to me, you must take backup pit file. After backup use Latest Samsung Odin with pit file. let me know if it worked. |
The Following User Says Thank You to how2solutions For This Useful Post: |
