Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
04-22-2017, 10:42 | #46 (permalink) | |
No Life Poster Join Date: Jun 2004 Location: sure...not at heaven... Age: 57
Member: 67494 Status: Offline Thanks Meter: 71 | Quote:
just flashed an set but will know how to end all,tryed to erase everithing from menu' of new firmware but after flash 5.11 phone still ask to an previous gmail account. | |
04-24-2017, 14:08 | #47 (permalink) |
Insane Poster Join Date: Jul 2012 Location: Romania
Member: 1782207 Status: Offline Sonork: 100.1638919 Thanks Meter: 16 | Reset to Factory in combination. After reset flash New firmware. Sent from my iPhone using Tapatalk |
The Following User Says Thank You to allingsm For This Useful Post: |
04-24-2017, 16:52 | #49 (permalink) |
Member: 1782207 Status: Offline Sonork: 100.1638919 Thanks Meter: 16 | I don't know more. I just explain my problem and Its finality. My Phone reset frp under combination firmware and there Factory reset. After that flash last 6.0.1. Sent from my iPhone using Tapatalk |
04-24-2017, 18:45 | #51 (permalink) |
Member: 67494 Status: Offline Thanks Meter: 71 | all done,flash combination then go to setting and erase all. phone in dwl mode,odin and stock 6.0.1,flash firmw,reboot,all ok! thnks a lot. |
09-03-2017, 09:37 | #54 (permalink) |
Freak Poster Join Date: Jun 2013 Location: Zimbabwe, mutare
Member: 1957238 Status: Offline Thanks Meter: 80 | combination files don't work for these models , it can only work by chance. Copy frpbypass.apk and gam6.apkto sdcard and put it in your phone. On start menu click start then turn wifi on and select more and select add network type any word and highlight it there will appear option like cut copy assist, select assist then it will take you to google search app then type file manager and choose frpbypass.apk and also gam6.apk which you must have downloaded earlier install both . enter your gmail and restart phone to complete setup just like on quickshortcut maker. |
09-03-2017, 09:49 | #55 (permalink) |
Member: 1957238 Status: Offline Thanks Meter: 80 | error while updating software when you try to downgrade your phone. to solvethis enter download mode and check your phone s boot version currently installed its written as b:3 or b:2 etc if b=3 then you should use file with u3 or s3 like this a310XXU3BQC2 OR A310XXS3BQC5 AND SO ON. For b=2 use a310xxu2bph2 there after use above method to unlock frp |
The Following 2 Users Say Thank You to Kukuphilmur For This Useful Post: |
