Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 06-15-2019, 13:28   #1 (permalink)
mediapeople's Avatar
Member: 759477
Sonork: 100.1618763
Thanks Meter: 111
A710FD custom binary blocked by frp lock
Hi i have this phone giving this message custom binary blocked by frp lock
not going in recovery mode tried combination tried latest build 7.0 indian & ksa firmware also but after flash same issue plz help me
Old 06-15-2019, 13:35   #2 (permalink)
Member: 2011612
Thanks Meter: 19
Hi. Flash 4file. Bl ap cp csc
Envoyé de mon SM-A600F en utilisant Tapatalk
Old 06-16-2019, 08:29   #3 (permalink)
Member: 759477
Sonork: 100.1618763
Thanks Meter: 111
can plz give me link for 4 files
Old 06-16-2019, 12:34   #4 (permalink)
Member: 2613252
Thanks Meter: 1,837
hello, to reset the custom binary blocked by frp lock, install the combination compatible with the phone's firmware.
once you have installed the combination if you have an octopus box using the emmc memory method using the uart cable, you reset the frp, once you reset the frp you flash the stock firmware in 4 files using ap, bl, cp and home_csc do not use csc ma use home_csc
in case you don't have octopus and you have z3x or other boxes do frp reset via adb then install stock firmware in 4 files as I wrote above
Old 06-16-2019, 12:48   #5 (permalink)
Member: 759477
Sonork: 100.1618763
Thanks Meter: 111
Hello i have octopus tried all ways tried with uart method but not success tried more than 6 firmwares tried combination but i flashed single file not 4 files because i don't have 4 files
Old 06-16-2019, 13:03   #6 (permalink)
Member: 2613252
Thanks Meter: 1,837
that you have installed android 7 firmware I need to know the binary and I look for the firmware in 5 files
Old 06-16-2019, 13:22   #7 (permalink)
Member: 759477
Sonork: 100.1618763
Thanks Meter: 111
This one i installed last both are 7.0 one is INS other is KSA
one more thing after write combination phone restarts & shows custom binary blocked by frp lock after write firmware same message here is file which i installed last
A710FXXU2CRK1_A710FDODD2CRK2_A710FDXXU2CRK1_HOME.t ar.md5
A710FXXU2CRL1_A710FOJV2CRL1_A710FXXU2CRL1_HOME.tar .md5
Old 06-16-2019, 13:36   #8 (permalink)
Member: 2613252
Thanks Meter: 1,837
Install this firmware in 4 file
Full Firmware A710FXXU2CQI6_A710FOXY2CQI5
download:
https://mega.nz/#!SixyRCSQ!vg7qwV0uW...sbARYGIoQWSLM0
Or this firmware
Full Firmware A710FXXU2CQH1 / OXY2CQH1 v7.0
download:
https://mega.nz/#!euhyRAYZ!v49Y9sdzq...wgKkmLLS6hrqfs
Password archive rar: windows4droid
Or you can download it from here all the firmware android 7 for a710f in full firmware based on the country and region of origin of the firmware your phone
https://updato.com/firmware-archive-...t=1&q=SM-A710F
remember to flash the firmware in 4 files ap, bl, cp, home_csc
and before installing the stock firmware, repeat the frp reset operation with octopus via uart cable with the combination installed
Old 06-16-2019, 16:22   #9 (permalink)
Member: 759477
Sonork: 100.1618763
Thanks Meter: 111
after flash with 4 firmware same result custom binary blocked
Old 06-16-2019, 19:25   #10 (permalink)
Member: 2613252
Thanks Meter: 1,837
did you install the combination and reset thefrp with octopus with the uart cable and did you try 4 files doing the firwarere flash using the home_csc file or did you use csc?
Old 06-16-2019, 21:01   #11 (permalink)
Member: 759477
Sonork: 100.1618763
Thanks Meter: 111
After write combination set is not coming in factory binary mode same message custom binary blocked & the firmware link you gave me have not home csc only csc & UART method also tried after combination but same result
Old 06-16-2019, 23:22   #12 (permalink)
Member: 2613252
Thanks Meter: 1,837
have you tried to download the firmware from updato and 'I third link should have 5 files including home_csc
Old 06-17-2019, 02:51   #13 (permalink)
Member: 759477
Sonork: 100.1618763
Thanks Meter: 111
in updato only single files available not 5 files
Old 06-17-2019, 04:17   #14 (permalink)
Member: 2011612
Thanks Meter: 19
Tri Samsung kies
The Following User Says Thank You to topetoil For This Useful Post:
Old 06-17-2019, 05:49   #15 (permalink)
Member: 759477
Sonork: 100.1618763
Thanks Meter: 111
i think it can be EMMC problem
Page generated in 0.25147 seconds with 9 queries
