Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
06-15-2019, 13:28 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: inside forum
Member: 759477 Status: Offline Sonork: 100.1618763 Thanks Meter: 111 | A710FD custom binary blocked by frp lock not going in recovery mode tried combination tried latest build 7.0 indian & ksa firmware also but after flash same issue plz help me |
06-15-2019, 13:35 | #2 (permalink) | |
Freak Poster Join Date: Aug 2013
Member: 2011612 Status: Offline Thanks Meter: 19 | Quote:
Envoyé de mon SM-A600F en utilisant Tapatalk | |
06-16-2019, 12:34 | #4 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
once you have installed the combination if you have an octopus box using the emmc memory method using the uart cable, you reset the frp, once you reset the frp you flash the stock firmware in 4 files using ap, bl, cp and home_csc do not use csc ma use home_csc in case you don't have octopus and you have z3x or other boxes do frp reset via adb then install stock firmware in 4 files as I wrote above | |
06-16-2019, 12:48 | #5 (permalink) |
Member: 759477 Status: Offline Sonork: 100.1618763 Thanks Meter: 111 | Hello i have octopus tried all ways tried with uart method but not success tried more than 6 firmwares tried combination but i flashed single file not 4 files because i don't have 4 files |
06-16-2019, 13:22 | #7 (permalink) |
Member: 759477 Status: Offline Sonork: 100.1618763 Thanks Meter: 111 | This one i installed last both are 7.0 one is INS other is KSA one more thing after write combination phone restarts & shows custom binary blocked by frp lock after write firmware same message here is file which i installed last A710FXXU2CRK1_A710FDODD2CRK2_A710FDXXU2CRK1_HOME.t ar.md5 A710FXXU2CRL1_A710FOJV2CRL1_A710FXXU2CRL1_HOME.tar .md5 |
06-16-2019, 13:36 | #8 (permalink) | |
Full Firmware A710FXXU2CQI6_A710FOXY2CQI5 download: https://mega.nz/#!SixyRCSQ!vg7qwV0uW...sbARYGIoQWSLM0 Or this firmware Full Firmware A710FXXU2CQH1 / OXY2CQH1 v7.0 download: https://mega.nz/#!euhyRAYZ!v49Y9sdzq...wgKkmLLS6hrqfs Password archive rar: windows4droid Or you can download it from here all the firmware android 7 for a710f in full firmware based on the country and region of origin of the firmware your phone https://updato.com/firmware-archive-...t=1&q=SM-A710F remember to flash the firmware in 4 files ap, bl, cp, home_csc and before installing the stock firmware, repeat the frp reset operation with octopus via uart cable with the combination installed Last edited by amleto90; 06-16-2019 at 13:42. | |
06-16-2019, 21:01 | #11 (permalink) |
Member: 759477 Status: Offline Sonork: 100.1618763 Thanks Meter: 111 | After write combination set is not coming in factory binary mode same message custom binary blocked & the firmware link you gave me have not home csc only csc & UART method also tried after combination but same result |
