A750FN remove MDM Hi Is there a way to remove MDM from A750FN, I've got the combination file but when I flash it back to normal the MDM comes back. Any help please, Thanks |
u can try chang serial by uart cable ur problem will fix |
Thank you for your reply Which box do you use to change serial? |
hello Quote:
this seems very good tips if provide command |
C:\Windows\system32>at+serialno=2 'at+serialno' is not recognized a operable program or batch file. how do you use this command, can you explain further more, if you don't mind..? |
will you please explain more, thanks.. |
please be more specific, port speed, etc I 'm used Putty terminal, on specific com port, but not response from phone. cable is from z3x used for serial frp remove Is need to be on combination mode for weite SN, is tested on U4? TNX, cris |
