Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 12-05-2018, 12:26   #1 (permalink)
Member: 118959
Thanks Meter: 6
A750FN remove MDM
Hi
Is there a way to remove MDM from A750FN, I've got the combination file but when I flash it back to normal the MDM comes back.
Any help please, Thanks
Old 12-05-2018, 23:54   #2 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,107
u can try chang serial by uart cable ur problem will fix
Old 12-06-2018, 17:56   #3 (permalink)
Member: 118959
Thanks Meter: 6
Thank you for your reply
Which box do you use to change serial?
Old 12-07-2018, 09:09   #4 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,107
no need box just use uart cable with AT comand
The Following User Says Thank You to CHANDARAKK For This Useful Post:
Old 12-14-2018, 09:59   #5 (permalink)
Member: 1558254
hello
can you teach me which AT Command ?
Old 12-14-2018, 11:15   #6 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 3,900
this seems very good tips if provide command
Old 12-19-2018, 15:40   #7 (permalink)
Member: 2752048
Thanks Meter: 15
which command should i use in cmd terminal
Old 12-22-2018, 10:23   #8 (permalink)
Member: 1264171
Thanks Meter: 74
at+serialno=2,abcdefghijk
Old 12-23-2018, 00:26   #9 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,107
u right AT+SERIALNO=2,gsmhosting
Old 12-27-2018, 19:55   #10 (permalink)
Member: 2406539
Thanks Meter: 24
showing error in cmd prompt..
C:\Windows\system32>at+serialno=2
'at+serialno' is not recognized a operable program or batch file.
how do you use this command, can you explain further more, if you don't mind..?
Old 12-28-2018, 00:40   #11 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,107
Use uart cable via box interfect
Old 12-28-2018, 06:12   #12 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 902
You cannot write it just in command prompt. To talk to phone you need to open link to it, at least with terminal emulation application to COM port that phone add and you see in device manager. The most common known app to handle your command is realterm ... so try it.
Page generated in 0.34864 seconds with 7 queries
