Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
07-02-2015, 14:18 | #1 (permalink) |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,975 | ALL}-Samsung Account Simple Method / Solution By AzimBahar* --------------------------------------------------- Reactivation lock lets you use your Samsung account to prevent others from activating your device if it's ever lost or stolen. With Reactivation lock turned on, you will be required to enter your Samsung account credentials prior to performing a factory reset on the device, so your Samsung account login should be something you can easily remember. This feature is not the same as Device lock, which is the password, PIN, or other method used to unlock your device when it has been turned off or inactive. FRP Lock (Factory Reset Protection)/ Google Account : ------------------------------------------------------------------- Android Factory Reset Protection (FRP) is a new feature to protect your device which has been added to several Samsung devices that are running Android OS 5.1 or higher. This feature allows you to set up your device to prevent other people from using it if it's been reset to factory settings without your permission. For example, if your device is lost, stolen, flashed, or wiped, only someone with your Google account or screen lock information can perform a factory data reset and use the device. When a device is factory reset, the device will not be able to be setup without the user entering the Google Account associated with the device (for hard reset) or screen lock information (for reset in Settings menu). Important! You must set up a Google account in order to utilize the FRP feature. It is highly recommended that you set a secure screen lock on your device. What Is The Solution ... ? ++++++++++++++++++ FRP Lock / Google Account Solution : (READ HERE) ----------------------------------------------------------------------- Reactivation lock / Samsung Account Solution Below Or (READ HERE) Let's me explain my simple method For Samsung account, You need to find a track for access to Samsung Apps or browser . You can get the track to help option Or keyboard setting (It's you can open from keyboard) ETC Other Way. After get the track you need try a comment to Samsung Apps store site ( Down the any apps ) and u will see login tab. Just login and do a comments after that come back to main menu and login with that id Which you used last time for the commends .In case it's unable to login just Hard Reset Your phone and once again try. All the android are same But for Samsung u need to commends to Samsung Apps. Simple it What Does I mean by Track ?Example : SAMSUNG KEYBORD SETTING - PREDICTIVE TEXT Its a track to access Browser :P For Browser : After get browser entry the link ( Samsung ) and login other all are same Code: http://www.samsung.com/us/support/account/ I have tested to many Samsung mobile Even Lollipop I used this method since Starting this problem Its Will help you if you findout the Track by your self Otherwise Sorry Maybe its old history for all Of you . But I shared for the new guy http://forum.gsmhosting.com/vbb/f777...1-1-a-2005623/ Br AzimBahar/ParvezAhmed Last edited by aZimBahar; 12-29-2015 at 04:24. |
The Following 17 Users Say Thank You to aZimBahar For This Useful Post: |
07-03-2015, 03:23 | #3 (permalink) | |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,975 | Quote:
Disabled by EE : http://forum.gsmhosting.com/vbb/f777...ed-ee-1959795/ Br AzimBahar/ParvezAhmed | |
The Following 3 Users Say Thank You to aZimBahar For This Useful Post: |
07-16-2015, 14:59 | #4 (permalink) |
Freak Poster Join Date: Dec 2010 Location: mumbai Age: 41
Member: 1467586 Status: Offline Thanks Meter: 80 | samsung s5 g900f model problem. samsung account lock 1st on ur mobile select all next next now coming ask samsung account ID 2ND U SEE DOWN SITE KEYPAD IN KEYPAD LEFT SITE ON SPACE BATTUN SETTING SYMBOL CLICK SYMBOL OPEN NEW FOLDER SAMSUNG KEYBORD SETTING] 3RD CHOICE PREDICTIVE TEXT 4TH SELECT LEARAN FROM FACEBOOK NEW MASSAGE COMING ATTENTION CLICK OK THEN ASKING GOOGLE ID PUT UR GOOGLE ID 5TH U SEE OPEN PLAY STORE SEARCH IN PLAYSTORE TYPE SAMSUNG ACCOUNT DOWNLOAD SAMSUNG LINK APP 6TH OPEN SAMSUNG LINK APP CLICK SIGN IN OPEN SAMSUNG ACCOUNT THERE 3 OPTION [SIGN] [CREATEACCOUNT] [SIGNUP WITH GOOLE ID] SELECT [SIGN UP WITH GOOGLE ID] 7TH UR ALRADY PUT PLAYSTORE ID SAME ID HERE USE PUT PASSWORD CONFIRM PASSWORD SELECT DATE OF BIRTH AND CLICK [SING UP] OPEN ACCOUNT AND UPDATE ALL FINISH FINISH THANKS |
07-23-2015, 11:18 | #5 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,975 | Note 3 lollipop :
Br:-) AzimBahar/ParvezAhmed Last edited by aZimBahar; 07-23-2015 at 11:25. |
The Following 7 Users Say Thank You to aZimBahar For This Useful Post: |
07-25-2015, 20:58 | #8 (permalink) |
Junior Member Join Date: Nov 2013 Location: targu jiu
Member: 2067480 Status: Offline Thanks Meter: 14 | Another solution. -when phone boot go to accesibility and export settings. Then share it via gmail . At gmail tap on settings button and add a samsung account. Works on 4.4.4 , 5.x |
07-28-2015, 17:33 | #9 (permalink) |
Junior Member Join Date: Jun 2015 Location: Spokane
Member: 2411046 Status: Offline Thanks Meter: 0 | hello everyone, any success with SM-G920V model S6 yet? I am stuck at Samsung account, did pwd reset and device is registered on my samsung account on the website, but it can't pass the samsung account setup on the device after entering the correct username/pwd details. |
08-05-2015, 04:25 | #11 (permalink) | |||
@...Forum Viewer G900F lollipop: You can downgrade to kitkat (Its downgrade safe, not effect to IMEI & BASEBAND) Then you can access from "Privacy Policy" Tested by one of my friend "Privacy Policy" tested work on note 3 Lollipop and G900F kitkat ! Each model depend on version and model , all are not same and enough information posted "Sorry" Quote:
Br:-) AzimBahar/ParvezAhmed Last edited by aZimBahar; 08-05-2015 at 04:30. | |||
08-21-2015, 07:43 | #14 (permalink) |
No Life Poster Join Date: Feb 2011 Location: ( United States Of Islam ) Age: 35
Member: 1519396 Status: Offline Sonork: 100.1612702 Thanks Meter: 1,951 | g531h i flash this erorr g531h i flash this erorr this device reset. to continue sing in with a google account that was previousaly synced on this device |
The Following 3 Users Say Thank You to niaz muhammad For This Useful Post: |
08-21-2015, 09:13 | #15 (permalink) |
Member: 1519396 Status: Offline Sonork: 100.1612702 Thanks Meter: 1,951 | g531h i flash this problime |
