Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 01-27-2018, 17:49   #1 (permalink)
imrangsmali's Avatar
Member: 2503555
Thanks Meter: 90
ALL Samsung PlayStore Fix Rom
E160L to N7000 Fixed Firmware download --} CuT URLs
The Following User Says Thank You to imrangsmali For This Useful Post:
Old 01-27-2018, 17:52   #2 (permalink)
Member: 2503555
Thanks Meter: 90
Galaxy On5 SM-G5510 Global Rom Android 6.0.1
[​IMG]​
Function:
Based on the Android 6.0.1
Build a Standard Samsung stock ROMs via Odin .tar.md5 Up
Remove all the components and China Apps
Internationalization, fully supported languages
Fix Secret code such as * # 06 #, * # 0 * #...
Change in frequency 2G / 3G / LTE auto, 2G only, 3G only, LTE only.
999 Message recipient limit .
[​IMG]​
Don't Rename files.
Must Unlock CROM Service before.
Download CROM App Here CuT URLs
Download Here: CuT URLs
Password: choimobile.vn
Old 01-27-2018, 17:56   #3 (permalink)
Member: 2503555
Thanks Meter: 90
Samsung Galaxy On5 (ON5 2016) SM-G5520 Global Rom
Rom Informations:
NO GOLDEN TRIANGLE
CSC tweaks:
★ Enable pin button voice calls
on mute ★ Allows photography
Recents ★ App lock panel on
Mobile data usage counter ★ notification panel on
camera Enable khi call ★
★ Disabled Auto-correction at the default for the Samsung Keyboard
★ Filming with the Samsung camera no longer pauses Music app (if you're playing music)
★ Messaging to it's original time stamps time
★ Enable backup / restore messages
★ Enable Call Button in call log list
★ Call / Message Settings entry blocking
★ 999 Message recipient limit
★ Exit button in the Samsung internet Browser
Vibrate on call answering ★
★ Extended Smart Manager (2nd page) with: App lock, permission / notification manager & call / message block
Fix Deesleep
Samsung boot logo Global
Support timer messaging
Support backup - not for messages from phone memory
Support to start - mute photography
Add Application "Samsung Music" International
Fix GPS navigation
International weather widget without Chinese
Automatically receive SIM contacts
Display of network data used in the Status Bar
Support for in-app lunar calendar default S Planner
Most applications access system
Password: (www. theprotch. com) Use password without spaces.
-::IF STOP SERVICE HAS GOOGLE PLAY::-
Then you go to the application manager and authorization for Google Play services is done.
Old 01-27-2018, 17:58   #4 (permalink)
Member: 2503555
Thanks Meter: 90
Galaxy On7 (SM-G6100) 4 file firmware Vietnamese, Fiexd All Problems
Vietnamese Full supported
Flash directly via Odin
No Knox trip (0x0)
Boot Logo Samsung Global
Completely remove the carrier app, app garbage
Fixed On7 lost imei, On7 imei null, On7 null baseband
Full file running when crashes logo.
Fixed logo hanging. Rom full support hanging files logo fix, bootloop!
Download Here, CuT URLs
Password: cellphones
Old 01-27-2018, 17:59   #5 (permalink)
Member: 2503555
Thanks Meter: 90
J3 pro J3119 ( J3 pro ver china) International Rom Final vesion
[​IMG]​
Rom is built on the latest stock: J3119KEU1APK1
Full Vietnamese
Fix GPS
Rooted
repeat 2 errors FIX message Messages
Messages unlimited characters
international weather Widget no Chinese
fully supported languages (including Vietnamese)
How To Flash:
Unlock Crom
Flash with latest odin
After Flash in wipe data and cache.
J3119KEU1APK1_5.1.1_20_01_2017.zip
Download Here CuT URLs
Old 01-27-2018, 18:00   #6 (permalink)
Member: 2503555
Thanks Meter: 90
Galaxy J7 J7109 (J7 china ver 2016) International Rom Fixed
Info:
Built on the latest stock: J7109KEU1BPL1 android 6.0
Full Vietnamese
Fix GPS
Unlimited Messaging characters
International Weather Widget no Chinese
Fully supported languages (including Vietnamese)
How To Flash:
Unlock Crom Sever
Flash using the latest odin.
J7109KEU1BPL1_XXV_6.0.1_20.01.2017.tar.zip
Password: choimobile. VN
Old 01-27-2018, 18:14   #7 (permalink)
Member: 2503555
Thanks Meter: 90
SAMSUNG SM-N900K & SM-N900S FIX firmware 5.0 fix MMI code & more
here is link download CuT URLs
Old 01-27-2018, 18:17   #8 (permalink)
Member: 2503555
Thanks Meter: 90
Samsung J3 (2016) J3109 International Rom Full Fixed Version​
Introduce:
Built on stock J3109KEU1APK3
CSC Vietnam
Fixed GPS
Fixed USSD Cods * # 06 #
Golden Tam Deleted
Fixed Messages characters limite Unlimted
Fixed International weather widget not have Chinese language
Fixed Internationalization, full support of languages
Installation:
Backup all data before start.
Download rom at the download link below.
Unlock Crom Sever
Use the latest odin to flash
After Flash Hard Reset (Full wipe) From Recovery with key.
Unlock SIM 1:
Open Factory IMEI APK And type: * # 27663368378 #
[2] UE SETTING & INFO
[1] SETTING
[1] PROTOCOL
[3] CDMA
[9] CTC SIM LOCK
[1] SIM LOCK
[2] SIM LOCK IS DISABLE
download CuT URLs
Old 01-27-2018, 18:19   #9 (permalink)
Member: 2503555
Thanks Meter: 90
G920P Convert To G920F Rom | Firmware
G920p To G920F rom Fixed
G920p USSD Cod Fixed
G920p SMS Fixed
G920p 2G, 3G, 4G Fixed
link CuT URLs
Old 03-06-2018, 08:26   #10 (permalink)
amirsaishi's Avatar
Member: 241938
Sonork: 100.1663699
Thanks Meter: 477
Originally Posted by zebafridi View Post
Plz file password......?
Old 03-17-2018, 14:29   #11 (permalink)
Member: 1824929
Thanks Meter: 99
need g3608 fix room..............................
Old 03-18-2018, 08:11   #12 (permalink)
Faheem Anjum's Avatar
Member: 399832
Sonork: Faheem Anjum
Thanks Meter: 24,310
Here is your File :https://mega.nz/#!mNhH3QIZ!KK3ZLYj5k...SPyyfY2cMvRXEU
The Following 2 Users Say Thank You to Faheem Anjum For This Useful Post:
Old 07-24-2018, 09:54   #13 (permalink)
Member: 2290305
Sonork: 1672955
Thanks Meter: 33
Originally Posted by Faheem Anjum View Post
The file you are trying to download is no longer available.
This could be due to the following reasons:
The file has been removed because of a ToS/AUP violation.
Invalid URL - the link you are trying to access does not exist
The file has been deleted by the user.
Old 11-29-2018, 12:16   #14 (permalink)
Member: 1572733
Thanks Meter: 2
need g3608 play store fix rom plz thnx in advance
Old 11-29-2018, 12:27   #15 (permalink)
Member: 1698141
Sonork: 1617901
Thanks Meter: 155
https://mega.nz/#!PTREFAoS!KK3ZLYj5k...SPyyfY2cMvRXEU
The Following 2 Users Say Thank You to nasiraslam For This Useful Post:
Page generated in 0.24838 seconds with 9 queries
