Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
10-04-2014, 18:01 | #1 (permalink) |
Freak Poster Join Date: Jan 2004 Age: 45
Member: 49428 Status: Offline Thanks Meter: 45 | -=[ Another Reactivation Lock Solution for Galaxy S5 (no root needed)]=- Galaxy S5 Note 3 (similar procedure, the key is Samsung Account) What you need: 1) S5 Needing Reactivation 2) working Samsung Account [I use same one for all my repairs] 3) wifi connection ready 4) Ability to follow directions below 5) Patience Step By Step: 1) If you have not already done so, do a complete factory reset via Stock Recovery and then reboot. As always initial boot will take time 2) When you get to the introductory activation screen SELECT ANY LANGUAGE and then Click NEXT 3) Will take you to WiFi Screen: Log into your WiFi make sure it shows connected. 4) Continue to the SIGN IN screen where it says "This device is locked because of abnormal reset... blah blah" 5) Scroll down to the blue "Forgotten Your ID or Password" and click on it 6) Now fill out your login with the Capcha and hit continue. Sometimes it might loop saying "Processing" etc hit back and try again. (It means not connecting to your wifi, you may not have this problem but I did). 7) It will now take you to next screen where it says: "Email for your password has been sent to your ID..." Now click on your blue email address. DO NOT CLICK ON CHECK INBOX 8) If you click on your blue email it will take you to next page that says "Webpage not available". You will see "mailto:[email protected]" . Now click and hold on it, you will get a drop down option from top bar. Click on the Earth icon for the internet. At this point on the Note 3 there is no Google now just click settings in the browser and select Account and then Samsung account and goto step 10. For S5 continue to to step 9. 9) It will ask you to use google now click yes. When it ask to login using what account select Samsung Account. (If it does not ask you or you see an existing gmail account there, it means you did not do factory reset so go back to step 1). 10) At the Samsung Account screen it will start to download update. Let it finish you can do anything about it anyway. But it is ok, relax almost done now (Note 3 skip to 13) 11) After it downloads updates it will take you to back to Google Now asking you again to use. Click yes. Click on settings and turn on the Google Now, it will ask AGAIN what account, select Samsung Account. 12) Will take you back to Samsung Account, login with your account this time. Once you are in, click back back back, back to activation screen. 13) Now back at the activation screen login using your Samsung Account. Complete the activation process 14) You can now goto settings>security> Uncheck "Reactivation Lock" 15) Don't forget to remove your account Hope this helps ! |
The Following 12 Users Say Thank You to KaBLooMz For This Useful Post: |
10-07-2014, 22:23 | #2 (permalink) |
Junior Member Join Date: Mar 2012 Location: Romania
Member: 1734120 Status: Offline Sonork: 100.1614365 Thanks Meter: 12 | Hope not make same as apple did with icloud !!! I mean you can .t bypass it ! |
The Following User Says Thank You to radudi For This Useful Post: |
10-29-2014, 17:27 | #3 (permalink) |
Freak Poster Join Date: Dec 2009 Location: UK. Worcester Age: 35
Member: 1176876 Status: Offline Sonork: 100.1607051 Thanks Meter: 154 | works very well......Tested on S5 G900F with latest fw. Thanks |
The Following 2 Users Say Thank You to Thorenzz For This Useful Post: |
12-03-2014, 17:22 | #6 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1212398 Status: Offline Sonork: 049 Thanks Meter: 4 | After the Samsung Account Update the phone automatically returns to google search what am I doing wrong Samsung G900F |
The Following User Says Thank You to TomSelleckx For This Useful Post: |
02-11-2015, 20:14 | #12 (permalink) |
Junior Member Join Date: Mar 2013
Member: 1907341 Status: Offline Thanks Meter: 0 | Any new solution, the method is not working anymore , Im stuck in "If you click on your blue email it will take you to next page that says "Webpage not available". You will see "mailto I can tap anywhere , NO ACCESS using wifi to internet o google |
02-15-2015, 11:42 | #13 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Big copy/paste from my unique original thread!!!! @KaBLooMz, First of open New Thread or GUIDE, always use SEARCH BUTTON for to see if there are already GUIDE posted. This is only a second Big COPY/PAST from my Unique and Original Thread open since 17/11/2013, nothingh of new only that in the 2013 the Galaxy S5 was not in the market, but my procedure Work good also in S5. THIS IS ORIGINAL LINK: Galaxy note 3_n-9005/S5 reactivaction samsung account In above link there are posted also Video "How To Remove Samsung Account". At today i have Add other Video for all you, "loock in my Original Thread", where can see how it work So, please S.Mod or Admin from "Forum Rules" seen that this thread is no double but is the 3° Copy/paste of my first open thread in 2013 can remove from "Sticky"?, or delete becouse already posted years ago. Best Regards allumts |
The Following 3 Users Say Thank You to allumts For This Useful Post: |
02-15-2015, 22:14 | #15 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @!!!_babu_!!!, Loock my above post with my thread link, there's one video that work also for S5 samsung, not work with Lollipop version, with 4.4.4 working fine tested by me 100% |
