Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
02-22-2017, 19:40 | #1 (permalink) |
Junior Member Join Date: Sep 2007
Member: 598532 Status: Offline Thanks Meter: 6 | Bypass note 4 - 910C Reactivation Lock on Android 6.0.1 STEPS 1. Connect to any wifi 2. Tap HOME button three times to enable TalkBack 3. Drag your finger UP then RIGHT to open TalkBack Menu 4. Tap TalkBack Settings 5. Hold both volume keys to disable TalkBack 6. Scroll down and tap on Play Store button 7. Tap at the top and search for Package Disabler Pro 8. Spend the $1.49 and download the app. While its installing also download Quick Shortcut Maker. 9. Open Package Disabler Pro and enable Admin, open the menu and tap Show System. 10. Scroll down and clear data and then disable Samsung Account & Samsung Setup Wizard. 11. Back out and open up Quick Shortcut Maker, find Setup Wizard NOT Samsung Setup Wizard! and tap it. Scroll down to the second to last option that says something like "Exit Setup". 12. Tap "Try" and you'll be into the Home Screen! 13. Go to Settings and then Backup & Reset then Factory Reset. 14. Open up Package Disabler Pro again and Enable ONLY Samsung Account, then return to the Factory Reset Page. 15. Tap ERASE ALL and you'll be prompted to Sign In with a new Samsung Account which will stay on your device from here on out! The only downside of this is that if you Factory reset your device the previous samsung account will still be on it so you will be locked out again. But as long as you don't do that then your device will never trouble you again! You can enable ADB, activate the carrier, do whatever you want at this point! Watch here Edit: I have downloaded and tried cracked version of Package Disabler Pro.apk from web instead of paying playstore, but failed the licence verification..so bought the app from playstore..if anyone tries and suceeded the cracked one pls let me know Last edited by ...:::::NP™:::::...; 09-10-2017 at 17:34. Reason: youtube link has been update |
The Following User Says Thank You to anzutvm For This Useful Post: |
03-01-2017, 11:50 | #3 (permalink) |
Insane Poster Join Date: Sep 2016 Location: Pakistan
Member: 2619139 Status: Offline Thanks Meter: 16 | This guide is for Android Version 6.0.1 Marshmallow and n910p having an Android Version 5.0.1 Lollipop. You should try this guide to Unlock n910p: Unlock Samsung Devices with Android 5.0.1 and 5.1.1 Lollipop |
11-09-2018, 17:56 | #6 (permalink) |
Freak Poster Join Date: Feb 2010 Location: sharjha
Member: 1236922 Status: Offline Sonork: sajer007 Thanks Meter: 101 | N910C reactivation lock done Using Version...1.0.0.0060 Selected Port Selected Model SM-N910C Selected Task SAMSUNG RLOCK_ADB Searching ADB device Please wait.. Device Detected... SELinux := Enforcing model:= SM-N910C Android Version:= 5.1.1 Description Version:= treltexx-user 5.1.1 LMY47X N910CXXS2CPB3 release-keys Platform:= exynos5 [ universal5433 ] [ DB7450R ] Baseband:= N910CXXU1COJ5 VER:= N910CXXS2CPB3/N910COJV2COJ2/N910CXXU1COJ5/N910CXXS2CPB3 Carrier := XSG_UAE EFS CSC := XSG Knox Warranty := Not Void Security Patch := 01-03-2016 ABI:= armeabi-v7a SDK Ver:= 22 Network Mode := 0 Simstatus:= READY ANDROID-ID = 41002519dcb01389_0000577F4B SU Version..kingo 141 Device is Secure Rooted..uid=0 System Permission is Read/Write... SAMSUNG RLOCK_ADB UNLOCK STARTED... Starting RLOCK Remove... Saving Backup... Preparing for RLOCK Remove.. Phone Found Wait... Model := SM-N910C SWVer := N910CXXS2CPB3 UNIQID := CR2002519DCB013 Phone IMEI := 3521****** REACTIVATION LOCKED... Fail to get reply for task2..NY7RDYQwDENXqilN4BMkWMP7b3G2dUhR1DgvdtfB9bI GsbNUzUJqj1KsO6IAEHpcGcuKV+O/rfU9BEzfooJt7hj2tIN8ZphkSTGDKHf8OycrWLvbCh+fLWLlRC TlYj/W3RX0GtORfhd0eh7s0/Pksf0A Please Reflash such phone... !!! SUCESS !!!! Total Time Take...00:03:35 Log Saved |
