Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
10-12-2019, 14:49 | #18 (permalink) |
Freak Poster Join Date: Mar 2013 Location: In your Mind Age: 35
Member: 1902758 Status: Offline Sonork: 100.1680534 Thanks Meter: 153 | Nobody can't help me.... Alhamdulillah Solve my Problem BY @Amar Ali07 with TeamViewer Thank you Brother |
The Following User Says Thank You to saifulhaq28 For This Useful Post: |
10-12-2019, 14:50 | #19 (permalink) |
Member: 1902758 Status: Offline Sonork: 100.1680534 Thanks Meter: 153 | |
10-12-2019, 15:13 | #20 (permalink) | |
Freak Poster Join Date: Dec 2017 Location: Pakistan Age: 24
Member: 2788598 Status: Offline Thanks Meter: 70 | Quote:
The Following 2 Users Say Thank You to Amar Ali07 For This Useful Post: |
10-12-2019, 15:39 | #21 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Portugal
Member: 478535 Status: Offline Thanks Meter: 433 | Reading the firmware versions for that model C9000 there are two types: ZC for china (open) ZH for HongKong Both only have binary U1. When you get phones like this one, you should pay attention to the country area and only use firmware from that area zc on phone with zc and zh on phone with zh. It may be this the problem. As it is Qualcomm maybe its possible to recover it by putting in edl 9008 and do the lowlevel fw reprogram, if any EDL FW is available of course and if its possible at all. I'm just theorizing as i never had to deal with such problem mainly with samsung phones build for the China networks! Glad that Amar Ali07 helped you get phone repaired. Maybe he could jump on board just to shed some light on what the recovery process is about. Not all the process obviously but just enough so people could get to the point that matters. Im downloading both firmwares zc and zh and going to try to compare both fw bins to see if there is much difference. In your case something was flashed until the error. I would really like to understand what happens to put a phone in this condition. Can you get the log from the program that you used that after flash gave you the error, to see witch files were flashed? |
11-11-2019, 07:16 | #23 (permalink) |
Member: 1902758 Status: Offline Sonork: 100.1680534 Thanks Meter: 153 | Contact with Amar Ali07 he can help you |
01-18-2020, 20:07 | #25 (permalink) |
Insane Poster Join Date: Jan 2006
Member: 219402 Status: Offline Thanks Meter: 12 | I got a T380 today and selectively flash files in a combo trying to enable adb to remove the passcode. then the error happened nothing can be flashed, screen shows fuse: -2, binary 2 the problem is "fuse: -2" I unpack the combo.tar, then tar each file. using odin, set auto reboot true, flashing each tar file. until you see fuse became a positive number, like in my case, fuse: 1 remember, avoid following files: apdp.mbn devcfg.mbn sbl1.mbn aboot.mbn flash stock. |
