Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
10-18-2016, 05:48 | #49 (permalink) |
No Life Poster Join Date: Apr 2007 Location: DUBAI, UAE
Member: 497374 Status: Offline Sonork: 1587252:AZAD Thanks Meter: 93 | just root the phone first unlock the frp lock and root the phone will be ok i just done it |
The Following User Says Thank You to azad4u For This Useful Post: |
02-04-2017, 08:25 | #50 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: >>>JANNAT<<<
Member: 1012319 Status: Offline Thanks Meter: 617 | Quote:
REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Repair DRK Selected model: SM-G925F Software version: 27.7 Checking local file... Ok Searching server... Ok Compare local and server file... OK (up to date) Searching USB Flash interface... COM4 detected Setup connection... Ok Reading data from phone... Ok Sending data to phone... Ok Sending data to phone... Ok Waiting ADB device... Ok Reading phone info... Recovery build version: 6.0.1 Boot version: G925FXXU5DQA7 Platform: exynos7420 Boot serial: 02157df2d062ae37 Product board: zerolte Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Checking DRK status... NG! Writing DRK... Ok Checking DRK status... Repairing DMVT key... Ok Rebooting phone... Ok Repair DRK done Done with Samsung Tool PRO v.27.7 | |
07-16-2017, 11:29 | #55 (permalink) |
Freak Poster Join Date: Mar 2015 Location: Nairobi
Member: 2358876 Status: Offline Thanks Meter: 78 | SAMSUNG GALAXY SM-G928C FRP AND DM-Verify SOLVED. SAMSUNG GALAXY SM-G928C FRP AND DM-Verify SOLVED ********************************** REMOVE FRP FIRST -FLASH SBOOT -- SBOOT_G928C_OJ5.tar -FLASH COMBINATION FILE--COMBINATION_FA51_G928CXXU2AOK1_CL5994902_QB7252768 _REV00_user_mid_noship.tar.md5.7z -USE MIRACLEBOX Reset FRP DM- verification Failed SOLVED *************************************** 1. Flash this FIRMWARE - XSG-G928CXXU3CQC7- Android 7 2. FLASH CF-Root - CF-Auto-Root-zenlte-zenltejv-smg928c.zip VIOLA SOLVED |
07-18-2019, 06:25 | #56 (permalink) |
Junior Member Join Date: Aug 2013 Location: kaduna
Member: 1994856 Status: Offline Thanks Meter: 1 | g925f dm-verity verification failed and reactivation account please whats the solution. because i cant root the device because of the samsung account and the phone is stocked on the bootloop.... |
07-18-2019, 12:50 | #57 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
hello, install the combination file compatible with the firmware and the binary installed on the phone, once installed the combination if you have octopus box or gc pro box through the uart cable fix the drk, once repaired the drk with the combination installed if you have octopus box or z3x box proceed to reset the samsung account or the frp account gmail using the Reset / EE Reactivation look option or using the ufs memory method via uart cable once the samsung account or frp gmail is reset, install the stock firmware of the phone in 4 files to restart it , using ap, bl, cp, Home_csc do not use csc Then it depends which account you need to reset if the samsung account or the frp gmail | |
