Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 02-27-2018, 16:15   #1 (permalink)
MGT SOFTWARE's Avatar
Member: 53263
Sonork: gsm master
Thanks Meter: 312
Easy Way to Remove Samsung Reactivation Lock any samsung
1. Flash with Combination file,
2. Download Minimal ADB and Fastboot.
3. Activate Adb Mode and assign USB debug ,
4. download: com.sec.android.app.samsungapps_4.2.19.3-
421903120_minAPI14(nodpi)_apkmirror.com.apk and Samsungservice.apk
5. Install gapps with this command: copy ADB install com.sec.android.app.samsungapps_4.2.19.3-
421903120_minAPI14(nodpi)_apkmirror.com.apk and past into minimal Adb and Fast boot, it will install apps.
6. copy and past ADB install Samsungservice.apk , it will install, now find the samsung account on the screen, and activate wi-fi,
7. use only activated samsung account with password, it will connect and clone the previous account.
8.Flash with Original firmware, when finish power on, use your activated account again to activate.
9. when connected, go to setting and remove your samsung account.
now the phone is working well.
C:\Program Files\Minimal ADB and Fastboot>dir
Volume in drive C has no label.
Volume Serial Number is F030-E366
Directory of C:\Program Files\Minimal ADB and Fastboot
02/27/2018 02:02 AM <DIR> .
02/27/2018 02:02 AM <DIR> ..
01/01/2017 02:10 AM 1,489,920 adb.exe
01/01/2017 02:10 AM 97,792 AdbWinApi.dll
01/01/2017 02:10 AM 62,976 AdbWinUsbApi.dll
04/11/2012 12:31 AM 59,904 bz2.pyd
08/09/2015 01:50 PM 29,882 cmd-here.exe
02/26/2018 06:53 AM 14,344,987 com.sec.android.app.samsungapps_4.2.19.3-
06/09/2013 08:56 PM 672 Disclaimer.txt
01/01/2017 02:10 AM 806,912 fastboot.exe
07/18/2013 12:13 AM 1,582,231 library.zip
04/11/2012 12:31 AM 2,303,488 python27.dll
07/18/2013 12:13 AM 18,944 py_cmd.exe
02/27/2018 01:56 AM 16,980,827 Samsungservice.apk
04/11/2012 12:31 AM 9,728 select.pyd
04/11/2012 12:31 AM 686,592 unicodedata.pyd
02/27/2018 01:06 AM 4,309 unins000.dat
02/27/2018 01:06 AM 719,521 unins000.exe
02/26/2018 07:12 AM 1,835 unins001.dat
02/26/2018 07:12 AM 717,985 unins001.exe
04/11/2012 12:31 AM 49,664 w9xpopen.exe
04/11/2012 12:31 AM 285,184 _hashlib.pyd
20 File(s) 40,253,353 bytes
2 Dir(s) 18,118,770,688 bytes free
The Following 22 Users Say Thank You to MGT SOFTWARE For This Useful Post:
Old 04-05-2018, 05:48   #2 (permalink)
Member: 1940476
Thanks Meter: 19
worked great! you're awesome!
The Following User Says Thank You to vinslyj For This Useful Post:
Old 04-10-2018, 15:53   #3 (permalink)
Member: 92260
Thanks Meter: 807
But this only works IF you have access to the main screen, in other words if you're not stuck on the setup screen. Any solution if stuck on the setup screen?
By the way here's the latest Galaxy Apps (com.sec.android.app.samsungapps)
https://www.apkmirror.com/?post_type...pp.samsungapps
Anyone has a good link for SamsungService.apk?
The Following 2 Users Say Thank You to BillA For This Useful Post:
Old 04-10-2018, 16:42   #4 (permalink)
Member: 1940476
Thanks Meter: 19
I didnít have access to the main screen at all. You have to follow this exactly how it is given. Flash combination file and then install files. Worked perfectly.
Sent from my iPhone using Tapatalk
The Following 2 Users Say Thank You to vinslyj For This Useful Post:
Old 04-10-2018, 20:43   #5 (permalink)
Member: 92260
Thanks Meter: 807
I didn’t have access to the main screen at all. You have to follow this exactly how it is given. Flash combination file and then install files. Worked perfectly.
Well duhh, silly me of course you get access to the main screen via combi... I was just testing ya... lol
And here's a source for the latest SamsungService app which is actually called Samsung Account (com.osp.app.signin):
https://www.apkmirror.com/?post_type...osp.app.signin
The Following 4 Users Say Thank You to BillA For This Useful Post:
Old 06-04-2018, 14:06   #6 (permalink)
Member: 2062071
Sonork: 100.1663486
Thanks Meter: 51
SamsungService.apk Link is here
https://androidfilehost.com/?fid=23578570567713902
Old 02-02-2019, 05:20   #7 (permalink)
Member: 2841276
Thanks Meter: 14
1. Flash combination
2.Connect to wifi and adjust correct date and time
3. Go to settings then accounts and sign in to samsung account
4. you should now see your phone here : https://findmymobile.samsung.com/#home
5. Go to settings>backup and reset and reset the phone with your samsung account.
6. flash orignal firmware
7. Enjoy Phone, now enable adb, root, etc to remove reactivation lock inside settings.
The Following 2 Users Say Thank You to charlesrichards For This Useful Post:
Old 02-02-2019, 05:35   #8 (permalink)
Member: 2062071
Sonork: 100.1663486
Thanks Meter: 51
Which model۔۔۔۔۔۔۔۔?
Sent from my SM-N920T using Tapatalk
Old 02-02-2019, 12:36   #9 (permalink)
Member: 322417
Thanks Meter: 906
I CANT UNDERSTAND HOW THIS GR8 POST HAS ONLY 4 THANKS INCLUDING MINE ONE
THIS POST DESERVE TO HAVE MORE THAN 100 THANKS BUTTON
AS I ALLWAYS SAY,
WHEN SOME PRODUCT MANAGER SAY HI
MEMBERS WILL RUSH THANKS BUTTON
WHEN WE GET SUCH GREAT SHARING POST LIKE THIS ONE ONLY 3 THANKS
THATS WHY MEMBERS ARE RESERVED IN SHARING SOLUTIONS THOSE DAYS
JUST CONTINUE IN THIS WAY UNTIL ADVANCED MEMBERS STOP SHARING ANY POSSIBLE SOLUTION....
WITH THANKS BUTTON WE HELP OUR SELF TOO
1. MEMBER WILL CONTINUE SHARE DUE THANKFUL MEMBERS
2. WHEN SOME MEMBER HAD A LOT OF THANKS PRESSED WE CAN FOLLOW HIS SOLUTION WITHOUT HESITATE TO DAMAGE OUR PHONES
OPEN YOUR EYES
The Following 4 Users Say Thank You to Formingus For This Useful Post:
Old 02-03-2019, 16:25   #10 (permalink)
Member: 2337583
Sonork: Hi dera
Good job Best of luck brother :-)
Old 02-03-2019, 17:23   #11 (permalink)
Member: 2447229
Thanks Meter: 6
I'm not able to sign off or reset
I'm not able to reset after login in the account always fails to remove parmanently pliz help or is there another procedure
Old 02-03-2019, 17:58   #12 (permalink)
Crazy Poster
Member: 2878099
Thanks Meter: 11
don't worry bro, wait for more thanx button
Old 02-06-2019, 08:39   #13 (permalink)
Member: 2886822
Sonork: 100.1682045
thanks for this reference,.
Old 07-13-2019, 06:56   #14 (permalink)
Member: 2287326
Thanks Meter: 12
Couldn't do this on an SM-A9100 (Oreo August 2018 security patch). I had to try many versions of "Samsung account" app because it would crash every single time until it started showing with this version "com.osp.app.signin_2.2.04.64-220464200_minAPI23"
But the problem is that it fails when I hit "next".
Is there a solution please?
Old 07-13-2019, 09:40   #15 (permalink)
Member: 14481
Thanks Meter: 84
That's what i call a hot solution.Thanks brother!
The Following 2 Users Say Thank You to golden_gsm For This Useful Post:
Page generated in 0.49048 seconds with 7 queries
