Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 07-06-2015, 16:48   #1 (permalink)
atou's Avatar
Member: 1388609
Sonork: atou
Thanks Meter: 156
EFS failed to mount for s4 SGH I545
no imei no baseband i try try no solution
can someone help
Old 07-06-2015, 17:27   #2 (permalink)
voltran2008's Avatar
Member: 861795
Thanks Meter: 1,275
efs failed to mount on recovery screen or no baseband? different issues?
phone boots or not? please be specific...
Old 07-06-2015, 18:29   #3 (permalink)
atou's Avatar
Member: 1388609
Sonork: atou
Thanks Meter: 156
Thx
phone boot normal but no baseband no imei
Old 07-07-2015, 13:28   #4 (permalink)
Member: 861795
Thanks Meter: 1,275
try flashing this modem via Odin:
androidfilehost.com - I545VRUFNK1_MODEM_w_HLOS_ODIN.tar
also please post what firmware you are on atm
Old 07-07-2015, 14:20   #5 (permalink)
atou's Avatar
Member: 1388609
Sonork: atou
Thanks Meter: 156
help
i flashed not work
firmware version i545VRUEMJ7 Android 4.3
Old 07-07-2015, 15:30   #6 (permalink)
Member: 861795
Thanks Meter: 1,275
flash this file via Odin:
4shared.com - backup.tar.md5
lemme know if flashing fails, i will upload a zip file flashable via custom recovery...
Old 07-07-2015, 16:03   #7 (permalink)
atou's Avatar
Member: 1388609
Sonork: atou
Thanks Meter: 156
mr.worldlinkmobil
recovery...
not flash write failed
Old 07-07-2015, 16:32   #8 (permalink)
Member: 861795
Thanks Meter: 1,275
flash this Custom Recovery via Odin:
twrp.me - twrp-2.8.7.0-d2vzw.img.tar
Enter Recovery Mode, Install Zip:
androidfilehost.com - Debrick-i545-MJ7.zip
Old 07-07-2015, 17:08   #9 (permalink)
atou's Avatar
Member: 1388609
Sonork: atou
Thanks Meter: 156
twrp.me - twrp-2.8.7.0-d2vzw.img.tar can t flash with odin fail
Old 07-07-2015, 18:50   #10 (permalink)
Member: 861795
Thanks Meter: 1,275
my bad.. since verizon bootloaders are locked and after 4.3 loki method dont work, only way is safestrap but thats a long story...
so easiest way to flash custom recovery your device, install Goo Manager from Play Store.. hit install openrecoveryscript.. select the file below (put into sdcard)... select reboot recovery...
file to flash:
dl.twrp.me - twrp-2.8.7.0-jfltevzw.img
Old 07-07-2015, 20:26   #11 (permalink)
Member: 861795
Thanks Meter: 1,275
file to flash:
forgot to mention requires root, so root your device before the process
Old 07-07-2015, 22:57   #12 (permalink)
atou's Avatar
Member: 1388609
Sonork: atou
Thanks Meter: 156
Mr
plz explain more step by step
thx
Old 07-07-2015, 23:09   #13 (permalink)
Member: 861795
Thanks Meter: 1,275
For rooting read this tutorial, there is also a video:
[ROOT] Saferoot: Root for VRUEMJ7, MK2, and Android 4.3
after you root your phone:
1.Download these files and put into sd-card:
-dl.twrp.me - twrp-2.8.7.0-jfltevzw.img
-androidfilehost.com - Debrick-i545-MJ7.zip
2.install Goo Manager from Play Store..
3.Run Goo Manager hit install Openrecoveryscript.. select the file "twrp-2.8.7.0-jfltevzw.img" from sdcard
4.Hit Reboot Recovery
5.In Recovery select update zip from sd card select "Debrick-i545-MJ7.zip"
Old 07-08-2015, 12:43   #14 (permalink)
atou's Avatar
Member: 1388609
Sonork: atou
Thanks Meter: 156
help
i try fail plz if yu have backup efs file
send me
thx
Old 07-08-2015, 12:54   #15 (permalink)
Member: 861795
Thanks Meter: 1,275
you can repair your efs with a box... will be super imei but will work...
Page generated in 0.29285 seconds with 8 queries
