EFS failed to mount for s4 SGH I545 no imei no baseband i try try no solution can someone help |
efs failed to mount on recovery screen or no baseband? different issues? phone boots or not? please be specific... |
Thx Quote:
try flashing this modem via Odin: androidfilehost.com - I545VRUFNK1_MODEM_w_HLOS_ODIN.tar also please post what firmware you are on atm |
help Quote:
i flashed not work firmware version i545VRUEMJ7 Android 4.3 |
flash this file via Odin: 4shared.com - backup.tar.md5 lemme know if flashing fails, i will upload a zip file flashable via custom recovery... |
mr.worldlinkmobil Quote:
not flash write failed |
flash this Custom Recovery via Odin: twrp.me - twrp-2.8.7.0-d2vzw.img.tar Enter Recovery Mode, Install Zip: androidfilehost.com - Debrick-i545-MJ7.zip |
my bad.. since verizon bootloaders are locked and after 4.3 loki method dont work, only way is safestrap but thats a long story... so easiest way to flash custom recovery your device, install Goo Manager from Play Store.. hit install openrecoveryscript.. select the file below (put into sdcard)... select reboot recovery... file to flash: dl.twrp.me - twrp-2.8.7.0-jfltevzw.img |
Mr Quote:
plz explain more step by step thx |
For rooting read this tutorial, there is also a video: [ROOT] Saferoot: Root for VRUEMJ7, MK2, and Android 4.3 after you root your phone: 1.Download these files and put into sd-card: -dl.twrp.me - twrp-2.8.7.0-jfltevzw.img -androidfilehost.com - Debrick-i545-MJ7.zip 2.install Goo Manager from Play Store.. 3.Run Goo Manager hit install Openrecoveryscript.. select the file "twrp-2.8.7.0-jfltevzw.img" from sdcard 4.Hit Reboot Recovery 5.In Recovery select update zip from sd card select "Debrick-i545-MJ7.zip" |
help Quote:
send me thx |
you can repair your efs with a box... will be super imei but will work... |
