Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
02-24-2016, 04:32 | #1 (permalink) |
No Life Poster Join Date: Jun 2003 Location: EGYPT Age: 44
Member: 31027 Status: Offline Thanks Meter: 179 | Free gift for all .....fix bootloop n910a 5.1.1 and also remove reactivation lock SO AFTER I SEE MANY PEOPLE GET THIS PROBLEM BOOT LOOP AFTER *#9090# AND MANY GUYS BUY IN PRIVATE AND TAKE MONEY AND RUN SO NOW IS FREE FOR ALL FIRST DOWNLOAD THIS FILE New folder (4) - Download - 4shared THIN EXTRACT FILE AND FLASH BY ODIN LAST ONE IF GET ERROR REMOVE MD5 LEAVE PHONE IT WILL BE OPEN NORMAL BUT WITH FACTORY BINARY NOW YOU HAVE ONLY 3 MIN TO FIX RESTART AND BASE BAND install KingRoot 4.0.0.233 by PC CONNECT TO WIFI AND ROOT PHONE YOUR PHONE WILL RESTART AFTER 3 MIN SO YOU HAVE 4 OR 5 TIME TO ROOT when you see KingRoot reaches 30% so now phone rooted thin Open "CMD" and type adb shell su "dd if=/dev/zero of=/dev/block/mmcblk0p10 | dd if=/dev/zero of=/dev/block/mmcblk0p13 | dd if=/dev/zero of=/dev/block/mmcblk0p14 | dd if=/dev/zero of=/dev/block/mmcblk0p15 | dd if=/dev/zero of=/dev/block/mmcblk0p16" AFTER THIS RESTART PHONE NOW ALL OK NOW RESET EFS BY ANY TOOL THIN WRITE CERT AND ALL OK LAST STEP NEED 4 FILE 5.1.1 TO UPDATE PHONE AND WORKING OK PS.. the phone often reboots before completed in first step, you have 3 min to do it ..must be quickly if you have REACTIVATION LOCK :ON NEED TO BECOME OFF JUST DOWNLOAD ANY GALAXY APPS.APK THIN INSTALL LIKE KINGO ROOT IN FACTORY BINARY THIN TYPE ANY ACCOUNT YOU KNOW IT AND AFTER UPDATE TO 5.1.1 AND ASK TO ACCOUNT JUST TYPE ACCOUNT YOU ADD BEFORE AND OK REMOVE CONGRATULATION NOW ALL OK AND NO SAMSUNG ACCOUNT BR...TAMER ELSOKARY |
The Following 33 Users Say Thank You to elsokary For This Useful Post: |
02-24-2016, 14:13 | #5 (permalink) | |
Freak Poster Join Date: Oct 2012 Location: .:::Egypt:::.
Member: 1823028 Status: Offline Sonork: 100.1622702 Thanks Meter: 43 | Quote:
All Thanx To My Brother Tamer Elsokary | |
The Following User Says Thank You to Esso Elkordy For This Useful Post: |
02-24-2016, 14:57 | #6 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | Also with simple command; adb install kingroot.apk Enviado desde mi SM-N920T mediante Tapatalk |
The Following 3 Users Say Thank You to yurais For This Useful Post: |
03-03-2016, 18:23 | #14 (permalink) |
Freak Poster Join Date: Aug 2011 Location: New York City
Member: 1637281 Status: Offline Sonork: 100.1657188 Thanks Meter: 95 | Ok here is a english tutorial instead of jibberish. HIT THANKS PLEASE!!!!!!!!!!!!!! I see this dude erased the link so PM me for the file because you will need it. Install KingRoot 4.0.0.233 from pc by pressing *#0808# then pressing ptp + adb then ok Use the mobomarket app to get kingroot on the phone. You fiqure it out but get that app on the phone. Connect the phone to wifi and root phone (Everytime the phone reboots you will have to restart the wifi again and do the kingroot again) It may take a couple tries but when the app goes real fast then goes to 100% then you will be rooted Caution****If the phone restarts root will be gone then you have to do it over**** Do it over and over until it (Percentage) goes real fast (usually on 3rd or 4th try) Have command open and copy and paste these commands real quick then press enter after the commands if needed Accept adb shell on the phone to be able to get su and as soon as it's granted type adb shell su dd if=/dev/zero of=/dev/block/mmcblk0p10 dd if=/dev/zero of=/dev/block/mmcblk0p13 dd if=/dev/zero of=/dev/block/mmcblk0p14 dd if=/dev/zero of=/dev/block/mmcblk0p15 (These commands are credited to Ecs87...He looked up the mmcblk's) After That Restart the phone and the phone will be OK This is what it will look like if you did it correctly.... 1|shell@trlteatt:/ $ su 1|root@trlteatt:/ # dd if=/dev/zero of=/dev/block/mmcblk0p10 /dev/block/mmcblk0p10: write error: No space left on device 8193+0 records in 8192+0 records out 4194304 bytes transferred in 0.293 secs (14315030 bytes/sec) 1|root@trlteatt:/ # dd if=/dev/zero of=/dev/block/mmcblk0p13 /dev/block/mmcblk0p13: write error: No space left on device 28673+0 records in 28672+0 records out 14680064 bytes transferred in 1.005 secs (14607028 bytes/sec) 1|root@trlteatt:/ # dd if=/dev/zero of=/dev/block/mmcblk0p14 /dev/block/mmcblk0p14: write error: No space left on device 8193+0 records in 8192+0 records out 4194304 bytes transferred in 0.353 secs (11881881 bytes/sec) 1|root@trlteatt:/ # dd if=/dev/zero of=/dev/block/mmcblk0p15 /dev/block/mmcblk0p15: write error: No space left on device 8193+0 records in 8192+0 records out 4194304 bytes transferred in 0.312 secs (13443282 bytes/sec) 1|root@trlteatt:/ # dd if=/dev/zero of=/dev/block/mmcblk0p16 /dev/block/mmcblk0p16: write error: No space left on device 9+0 records in 8+0 records out 4096 bytes transferred in 0.005 secs (819200 bytes/sec) If still on Binary firmware, just write cert if imei is/01 You can use Z3X with it just like that or with gcpro you might have to reset/write default efs. Last step is to flash the phone back to stock. Congratulations. Your phone is saved. Please hit the thanks button 3 times. Lol I need more thanks. |
The Following 7 Users Say Thank You to concepttheman For This Useful Post: |
