Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
09-22-2019, 23:21 | #1 (permalink) |
Freak Poster Join Date: Oct 2017 Location: Danmark
Member: 2763847 Status: Offline Thanks Meter: 61 | Free solution U6 FRP ON DRK G935F G930F OEM lock on failed to mount system rw For G930F flash this file: G930F_Binary6_DRK_FIX When phone is started enable OEM unlock and root / follow instructions in text file inside ZIP file you done the download with For G935F flash this file: G935F_Binary6_DRK_FIX When phone is started enable OEM unlock and root / follow instructions in text file inside ZIP file you done the download with Enjoy free solution by Augustin If you need this file for any other phone I can create this for you just say me your binary version and phone model number enjoy the free solution always |
The Following 6 Users Say Thank You to AUGUSTIN45 For This Useful Post: |
11-23-2019, 14:32 | #9 (permalink) | |
Member: 2763847 Status: Offline Thanks Meter: 61 | Quote:
G930F..Nothing I found It is Oreo..Have you try the standard practices for bypass FRP? The Oreo classics? Somethings to try.. https://www.youtube.com/watch?v=k73dQOXPAJU https://www.youtube.com/watch?v=yz7aEYRfiXc | |
12-17-2019, 18:14 | #12 (permalink) |
Freak Poster Join Date: Nov 2004 Location: canary island Age: 45
Member: 93421 Status: Offline Thanks Meter: 19 | If you need FRP Off on G930F U6 use this video: https://www.youtube.com/watch?v=T5caJAdahdU Work fine |
03-01-2020, 01:38 | #13 (permalink) |
Junior Member Join Date: Nov 2011
Member: 1694722 Status: Offline Thanks Meter: 0 | G930F_Binary6_DRK_FIX.zip Flashed with ODIN file from Augustin45 's first post: file G930F_Binary6_DRK_FIX after reboot, it goes into boot-loop, SAMSUNG logo blinking, let it run for hours...no change. and to make situation worse, it changed bootloader from b:5 to b:6, and there is no COMBINATION file for v6 and thanks to SAMSUNG's boot version lock, no bootloader downgrade possible |
03-01-2020, 20:40 | #14 (permalink) | |
Flash then my file again WITHOUT enabled nand erase This time it working 100000% Go setup phone, if required then bypass FRP, then go to settings and enable OEM unlock Then root phone or do as needed Fully working fix | |
03-17-2020, 01:43 | #15 (permalink) | |
Insane Poster Join Date: Nov 2007 Location: Italy Age: 46
Member: 632556 Status: Offline Thanks Meter: 4 | Quote:
Hey bro, not working for me, logo samsung blinking | |
