Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
10-27-2018, 06:28 | #1 (permalink) |
Freak Poster Join Date: Nov 2008 Location: VietNam Team Age: 49
Member: 890799 Status: Offline Sonork: 100.999999 Thanks Meter: 384 | FRP Bypass Solution For Android Pie 9.0 Required tools for unlocking FRP 9.0 android p Combination firmware from -> http://combinationfirmware.com/ Samsung firmware from -> https://pangu.in/samsung-firmware/ Samsung Odin3 3.12 -> https://pangu.in/odin-3-12-3-samsung...amsung-device/ First shut Down the device and put the device into download mode to put the device into download mode you have to press and hold the Bixby key volume down key and Power keys together Now press the volume UP button to continue install the Samsung*USB driver before starting the process you can download the latest driver from above. Now insert the USB type C cable into locked Samsung*device Open Odin and select the Combination file into AP field. Now click on Start Button to start flashing After the flash,*go setting and select the developer mode and enable the USB Debugging option. And flash the stock firmware Now the Samsung*firmware has been unlocked Last edited by ...:::::NP™:::::...; 10-27-2018 at 07:05. Reason: F.B Link Not Allowed, Unnecessary, spelling was deleted |
10-27-2018, 19:32 | #4 (permalink) |
Freak Poster Join Date: Feb 2005 Location: At the Shop
Member: 120273 Status: Offline Thanks Meter: 57 | Are you saying simply flashing combo and enable adb then reflash stock will remove frp? |
The Following User Says Thank You to Araltd For This Useful Post: |
