Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
06-16-2015, 17:23 | #1 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Rawalpindi, Pakistan Age: 35
Member: 2157308 Status: Offline Sonork: 100.1655088 Thanks Meter: 677 | [Full Solution] This Phone Is Disabled by EE I was getting requests everyday to post full solution for "This Phone is Disabled by EE" but i was very busy in other some stuff, so finally today i have decided to post the solution to help you guys. Solution This data is in persist partition in samsung phone named (persdata) of the phone so you need to format it to fix your phone. But to format this partition you need access to "adb shell" to communicate with phone. 1. First of all find latest CWM/PHILZTOUCH/TWRP recovery for your phone and flash it using odin. 2. Boot you phone in you custom recovery and connect the cable make sure its detected as adb device in you device manager to confirm you can also run the command in CMD ''adb device" 3. Now you are ready to format your persist partition. (This is for S5, Note3 and Note 4) Code: adb shell mke2fs /dev/block/platform/msm_sdcc.1/by-name/persdata dd if=/dev/zero of=/dev/block/platform/msm_sdcc.1/by-name/persdata exit 4. For Galaxy Alpha and latest models commands are almost same but partition table is little bit different so first of all you need to run this command to determine where is persdata in the partition. Code: ls /dev/block/platform And you will see something listed, e.g. “15540000.dwmmc0″. So you would then replace “msm_sdcc.1″ with “15540000.dwmmc0″. The above command will then become Code: mke2fs /dev/block/platform/15540000.dwmmc0/by-name/persdata For S6 : G920f Root with this file Root And install this recovery twrp-2.8.6.2 And use this command Code: adb shell dd if=/dev/zero of=/dev/block/sda11 dd if=/dev/zero of=/dev/block/sda13 And the final step is to Wipe Dalvik & data / factory reset. Its always recommended to flash phone with other firmware then EE uk region firmware so that this will never come back. Good Luck |
The Following 40 Users Say Thank You to androidlabs For This Useful Post: |
06-16-2015, 17:37 | #2 (permalink) |
No Life Poster Join Date: Sep 2002 Location: India
Member: 15238 Status: Offline Thanks Meter: 128 | Amazing Compilation and Salute to great Hardwork done by you Although it may be not a FULL Discovery but still you deserve a lots of hearty thanks from all of us here on this versatile forum. Warmest Regards |
The Following 4 Users Say Thank You to i_seeque For This Useful Post: |
06-16-2015, 17:55 | #4 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | Good work, thanks This procedure can also remove Reactivation lock in other Samsung phones and not just DIsabled by EE? BR |
The Following User Says Thank You to byteforce For This Useful Post: |
06-16-2015, 17:59 | #5 (permalink) | |
Member: 2157308 Status: Offline Sonork: 100.1655088 Thanks Meter: 677 | Quote:
********Other members please use thanks button********** | |
The Following 13 Users Say Thank You to androidlabs For This Useful Post: |
06-17-2015, 07:27 | #6 (permalink) |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,126 | this solution posted another website one month before ?This phone has been disabled by EE? Absolute Software Computrace? ? Free solution: All Samsung ? Cell Rabta |
The Following 2 Users Say Thank You to Mr.3. For This Useful Post: |
06-17-2015, 07:33 | #7 (permalink) | |
The Following User Says Thank You to androidlabs For This Useful Post: |
06-17-2015, 08:11 | #8 (permalink) |
Freak Poster Join Date: Mar 2014 Location: Heart
Member: 2144988 Status: Offline Sonork: 100.1655364(Offline) Thanks Meter: 217 | Really Great&Amazing HardWork Done by Andriodlabs Many Person Face This Problem EE Disabled But Not Found Any Working,Tested&Perfect Solutions This Method Working Perfect U Deserve It For This Solution and U Done It By Your Hard Working Keep It Up WBR Hifzul Amin |
06-17-2015, 15:56 | #9 (permalink) |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | Not one mention of where the original information came from...astounding. This thread was started in January 2015: http://forum.gsmhosting.com/vbb/f453...ed-ee-1899259/ As far as I know, that's the origin of the EE fix. And as far as I know...the original author of it (ahem) is reluctant to continue his work on it due to situations like this. Absolutely no recognition or credit whatsoever for others. Sigh. |
The Following 3 Users Say Thank You to ecs87 For This Useful Post: |
06-17-2015, 16:36 | #10 (permalink) | ||
Yes Obviously Smith you are the first one to introduce the solution of EE disabled phone i really respect you for that and if you remember i am the first person to contact you about this problem at that time you didn't even know what actually this security is but you gave me some a guess and told me that it might be in persist partition and i am literally so much great-full to you and i consider you as my good friend and as far as credits are concerned and as you mentions that Quote:
The reason i have posted the full solution because you stopped making new files and some people was taking advantage and selling files. i didn't wrote that its the worlds first solution. Don't disheart you are very important member of the forum and always will be ..don't care much about thanks meter my thanks meter is less then yours even i have 90% of my threads sticky on different sections Cheerup Smith | ||
06-18-2015, 08:55 | #11 (permalink) | |
Freak Poster Join Date: Jan 2004 Location: PAKISTAN Age: 52
Member: 48518 Status: Offline Sonork: 100.113013 Thanks Meter: 127 | Quote:
Br Xtreme | |
The Following User Says Thank You to xtreme For This Useful Post: |
06-18-2015, 10:29 | #12 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,308 | Quote:
same method not working for all model becoz the partition layout changed for every phones there is some phones which have same if you have M9 in hand and want to solved the problem feel free contact me | |
06-18-2015, 11:27 | #13 (permalink) | ||
and there is a reason why this post is in Samsung android based section. looks like more criticizers then supporters but i knew already before posting that this will happen...... | ||
