Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
02-02-2018, 05:56 | #1 (permalink) |
Junior Member Join Date: May 2016
Member: 2569869 Status: Offline Thanks Meter: 0 | G920F and A520F on andriod 7.0 FRP Problem Help!! :( thanks |
02-02-2018, 12:53 | #2 (permalink) |
Freak Poster Join Date: Aug 2016
Member: 2616438 Status: Offline Thanks Meter: 147 | Many ways to solve your problem If you want to use combination procedure Which can be applied as a general solution Flash full combination which by the way should be the same binary as the phone ex: (a520fxxu2 ) then 2 is the binary level of which the combination should be No matter 6.0.1 or 7.0 After the phone boots up . Flash stock firmware of the same binary ofcourse but with z3x flash ignoring userdata,pit,hidden And using homeCSC file The phone will boot up know with no setup now go to setting and reset phone. You are done |
The Following User Says Thank You to wadda7o For This Useful Post: |
02-02-2018, 18:11 | #3 (permalink) |
Member: 2569869 Status: Offline Thanks Meter: 0 | Hi, thanks for the kind reply i will try this also when i flash factory then flash firmware sometimes some files remain i.e sticks on sdamsung logo and also download mode has loads of yellow n green writeing like some of the combination files still in there. i have tried flashing the same way before but lock remains on thanks |
02-02-2018, 18:36 | #4 (permalink) |
Member: 2616438 Status: Offline Thanks Meter: 147 | Concerning the writings in the download mode its a normal thing especially in new devices such as note8, s8, and s8+ so dont worry For the phone to boot up after flashing stock firmware coming up from combination will take some time 2 or 3 min. Try to choose close versions of combination and firmware to avoid being held on samsung logo Be carefull to not flash userdata, pit so that the phone will not be resetted So you are supposed to flash ( sboot, boot, system ,recovery , modem) This will be enough |
02-02-2018, 19:15 | #5 (permalink) |
Member: 2569869 Status: Offline Thanks Meter: 0 | Hi, thanks for your reply.. ok so i have flash comb and then looked through the stock but there is no userdata in any of the folders. i have to delete hidden and flash just the cache of the home csc as it fails i dont know y. pretty new at this but im quick at learning |
02-03-2018, 11:34 | #8 (permalink) |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Here you got tutorial with links to combination files that you need. SAMSUNG G950F Galaxy S8 - Frequently Asked Questions about resetting your device - HardReset.info
__________________ Please do not Personal Message me for help or troubleshooting. They will be ignored. Use the forums! To get Instant help use "search" & follow "sticky thread"..!!! By respecting/following forum rules,You will be respected .! |
02-12-2018, 20:05 | #9 (permalink) |
Member: 2569869 Status: Offline Thanks Meter: 0 | I have another problem i have a samsung galasy s6 edge removed frp via combination i then download latest firmware and installed it prob is its andrion 7.0 i have had to root it cos it said something about been dirty so had to root it to fix drx error its sim locked and no box will unlock it z3x does not show imei or the csc and *#06# does not bring up the imei any advise please |
02-12-2018, 20:16 | #10 (permalink) | |
Member: 2616438 Status: Offline Thanks Meter: 147 | Quote:
02-12-2018, 20:34 | #11 (permalink) |
Member: 2569869 Status: Offline Thanks Meter: 0 | Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G928F Timezone: Europe/London Android Version: 7.0 [NRD90M] Build Date: Thu Jan 4 11:57:08 KST 2018 PDA Version: G928FXXS4CRA1 [january 2018, rev1] Phone Version: G928FXXU4CRA1 [january 2018, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON333 Serial Number: R58H12YGF1D |
02-12-2018, 21:04 | #13 (permalink) |
Member: 2569869 Status: Offline Thanks Meter: 0 | Checking hash file... OK Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G928F Android version: 7.0 Product code: SM-G928FZKAEVR Phone version: G928FXXU4CRA1 PDA version: G928FXXS4CRA1 CSC version: CSC country code: CSC sales code: HW version: MP 0.500 Phone S/N: R58H12YGF1D Modem board: SHANNON333 RF cal date: 20160123 IMEI: tried 3 diff cp files nothing works imei does not show on screen |
02-12-2018, 22:00 | #14 (permalink) |
Member: 2616438 Status: Offline Thanks Meter: 147 | https://mega.nz/#!oV0n0YJT!rfPhhdPi1...qoJxt928FrVcbg Try this modem |
02-12-2018, 22:00 | #15 (permalink) |
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Mean imei damaged only cert write can help. Org imei is lost if you do not have backup.
The Following User Says Thank You to wgmmmx1 For This Useful Post: |
