Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
11-09-2018, 21:19 | #1 (permalink) |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | G930P + G930A + G930T + G9350 + G930V+ G930T1 Combination G930AUCU8ARJ2 ( BINARY 8) For this combination binary 8 SM-G930 these models are compatible Combination Model : G930P , G930A , G930V(x) , G930T , G930U, G930T1 COMBINATION_VZW_FA60_G930AUCU8ARJ2 Link download: COMBINATION_VZW_FA60_G930AUCU8ARJ2_VZWFAC_CL739670 6_QB20148956_REV02_user_mid_noship_MULTI_CERT.tar. md5 |
The Following 3 Users Say Thank You to amleto90 For This Useful Post: |
11-09-2018, 23:33 | #2 (permalink) | |
Freak Poster Join Date: May 2017 Location: NYC
Member: 2721132 Status: Offline Thanks Meter: 39 | This is a good posting, thank you for sharing!! BR Quote:
11-10-2018, 17:49 | #3 (permalink) |
Junior Member Join Date: Nov 2018
Member: 2876523 Status: Offline Thanks Meter: 1 | I can load the combination file but it doesn't get rid of the frp. I've flashed the boot img and boot loops. Flashed the whole file works but doesn't erase the frp. Used octoplus frp tool , umt box nothing. Any help I'm trying to do sm-g930t |
11-10-2018, 17:57 | #4 (permalink) | |
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
ap, bl, cp, csc_home? I have unselected the userdata or metadata partitions for single firmware files | |
11-10-2018, 18:12 | #5 (permalink) |
Member: 2876523 Status: Offline Thanks Meter: 1 | I flashed the combination then tried to flash my stock AP,bl,cp,home csc and most of the time get error wrong size . I have gotten the stock back on with a T-Mobile pit and reflashing over and over. Can u give me step by step of what I need to do from the beginning |
11-10-2018, 18:17 | #6 (permalink) | |
in addition to flashing the 4 files ap, bl, cp, csc_home you have removed the partition files from the individual files or you only did the flash of the 4 files without removing the files of the single file | |
11-10-2018, 18:43 | #8 (permalink) |
Member: 2613252 Status: Offline Thanks Meter: 1,837 | make the flash of the combination use octopus and reset frp via adb and reset the frp make a factory reset, then when you do the firmware flash stock write three files ap, bl, csc_home before flashing the firmware stock deselect from ap and remove these files recovery.img "," cache.img ", and" userdata "partitions, once you remove these files you can flash the sign and see if the frp is still active or reset |
11-10-2018, 20:07 | #10 (permalink) |
Member: 2613252 Status: Offline Thanks Meter: 1,837 | you have to select through octopus software go in advanced mode to write the firmware select the single file ap and deselect the three files recovery.img "," cache.img ", and" userdata "partitions and then make the flash of the firmware read this post even if it is of z3x it makes you see uncheck these 3 files from ap http://forum.gsmhosting.com/vbb/f453...8-0-a-2443856/ |
09-04-2019, 16:45 | #12 (permalink) |
Banned Join Date: Dec 2018 Location: India
Member: 2885667 Status: Offline Thanks Meter: 39 | Bro you can get your combination for Samsung S7 Edge |
