G935F U3 Binary Combination File & FRP Solution Need i tried this U3 combination, at first i was able to boot the phone normally and followed the normal procdture to remove FRP however after flashing U3 Stock back to phone the FRP was not removed ... so i tried to flash the same combination and it does not work any more gives the same bootloader execption error .... any more ideas ??? COMBINATION_FA60_G935FXXU3ARI2_CL7964511_QB1963552 1_REV00_user_mid_noship this is not working any more ... Pls provide any other solution if possible .. br |
flash that combination file with odin and after flash only bl and ap file |
Please firmware link |
br |
****************************/file/j7asg...r.md5.zip/file |
thanks bro but its not working |
1- flash combination with the right security.. 2- go to setting and enable oem 2- flash firmware with HOME Csc. ------ 3 - if u didn't find oem , just flash from stock firmware with the right security.(sboot+boot+system+recovery+cache) . 4- after starting the phone enable oem and make reset from settings. |
1- Flash combination . 2- remove FRP UART method 3- flash full stock ROM & thats it. Additional: after removing of FRP Via UART method you can check on Download Mod that there is FRP: off Tested many time |
Flash Combination and Remove FRP via UART Then flash full file |
Samsung FRP Bypass 2018 Method 1 : Samsung FRP Bypass 2018 Method 2: Samsung FRP Bypass 2018 Method 3: |
after combination flash go to developer options and enable stay awake and usb debugging then flash only bl and ap |
