Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 09-29-2018, 11:18   #1 (permalink)
Member: 1280253
Thanks Meter: 139
Question G935F U3 Binary Combination File & FRP Solution Need
i tried this U3 combination, at first i was able to boot the phone normally and followed the normal procdture to remove FRP however after flashing U3 Stock back to phone the FRP was not removed ... so i tried to flash the same combination and it does not work any more gives the same bootloader execption error .... any more ideas ???
COMBINATION_FA60_G935FXXU3ARI2_CL7964511_QB1963552 1_REV00_user_mid_noship this is not working any more ...
Pls provide any other solution if possible ..
br
Old 09-29-2018, 12:29   #2 (permalink)
Member: 2827177
Thanks Meter: 19
flash that combination file with odin and after flash only bl and ap file
The Following 3 Users Say Thank You to ramanmultani949 For This Useful Post:
Old 10-01-2018, 06:11   #3 (permalink)
adnanali's Avatar
Member: 207308
Thanks Meter: 437
Please firmware link
Old 10-01-2018, 11:13   #4 (permalink)
Member: 1280253
Thanks Meter: 139
tanx bro was able to boot it finally ..
br
The Following User Says Thank You to manbir For This Useful Post:
Old 10-01-2018, 11:14   #5 (permalink)
Member: 2613252
Thanks Meter: 1,171
https://www.mediafire.com/file/j7asg...r.md5.zip/file
Old 10-04-2018, 12:36   #6 (permalink)
Member: 2647181
Thanks Meter: 8
thanks bro but its not working
Old 10-04-2018, 15:28   #7 (permalink)
Member: 2723574
Thanks Meter: 3
1- flash combination with the right security..
2- go to setting and enable oem
2- flash firmware with HOME Csc.
3 - if u didn't find oem , just flash from stock firmware with the right security.(sboot+boot+system+recovery+cache) .
4- after starting the phone enable oem and make reset from settings.
The Following 2 Users Say Thank You to ahmed26h For This Useful Post:
Old 10-25-2018, 19:42   #8 (permalink)
khanzada606's Avatar
Member: 2455344
Sonork: Ask me
Thanks Meter: 343
1- Flash combination .
2- remove FRP UART method
3- flash full stock ROM & thats it.
Additional: after removing of FRP Via UART method you can check on Download Mod that there is FRP: off
Tested many time
The Following 4 Users Say Thank You to khanzada606 For This Useful Post:
Old 11-16-2018, 08:27   #9 (permalink)
Member: 1890442
Sonork: 100.1621735
Thanks Meter: 38
thanks a lot my problem solved
Old 12-06-2018, 12:53   #10 (permalink)
Member: 2762776
Thanks Meter: 18
Flash Combination and Remove FRP via UART
Then flash full file
Old 12-07-2018, 12:22   #11 (permalink)
Mobile-Lab's Avatar
Member: 10028
Sonork: n/a
Thanks Meter: 537
HERE are EASY methods without PC/COMBINATION
Samsung FRP Bypass 2018 Method 1 :
http://www.youtube.com/watch?v=-N1c9ybe-0I
Samsung FRP Bypass 2018 Method 2:
http://www.youtube.com/watch?v=OY7hmqRneY0
Samsung FRP Bypass 2018 Method 3:
http://www.youtube.com/watch?v=Zx8_DLcSHgs
Old 12-30-2018, 13:36   #12 (permalink)
Member: 2880877
after combination flash go to developer options and enable stay awake and usb debugging then flash only bl and ap
Page generated in 0.31513 seconds with 7 queries
