Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 11-17-2013, 23:49   #1 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Galaxy Note 3 N9005 Reactivaction Lock Samsung Account Problem
Hello, have one device of this Locked in Samsung Account, have read that first of any Factory Reset or Wipe needed export File or Flash whith the Update "UDMJ6" base for put of default Loock OFF, but not all know this and now i've device in this state:
Is loked in Samsung Account, from Download Mode can flash any Fw whith success but there is ENABLED Write ON, anybody can help for get out from this mode or recovery in LOCK WRITE OFF?,
thank in advance
Max
Old 11-18-2013, 13:57   #2 (permalink)
allumts's Avatar
Member: 1564612
Hello, have find this NEW over REACTIVACTION of LOCK OFF:
International Galaxy Note 3 getting another OTA, reactivation lock now defaults off | Android Central
Loock Here:
Anybody know if is possible to flash this update, (i'm not have this Fw base UDMJ6), only via Sd Card or Full Fw always via Sd Card and if Solve this Problem?,
thank in advance
Old 12-04-2013, 11:36   #3 (permalink)
allumts's Avatar
Member: 1564612
Solved note 3 n9505 samsung account
FOR ALL USER WHITH NOTE 3 N-9505 that have Wiped/Factory reset your phone and now have only SAMSUNG ACCOUNT request Locked in the SCREEN, here a little, speed and Tested By to me SOLUTION:
First Solution Tested and Working:
Goto accessibility option which is available on the first screen where you select language..then goto Text to speech option..then from the settings goto Install voice data and try to download any language..It will ask you to enter samsung account details...Enter your own samsung account details..once the download is complete..go back to screen where it was showing abnormal factory reset adn then enter your samsung account..It will go through..
Second Solution Tested and Working:
First of all I have to say that I've created this account just to share what I did with this problem. It took me, after doing dozens of hard reset and flashing firmwares, 10 minutes. Maybe, the seller never activated the phone (that's what happened to me) and this screen is appearing by mistake. So what you have to do if this is your case is to connect the headphones that came with the phone and press the button for 1-2 sec. Then the SVoice will apear and there you can use voice commands. So you just say "Start Settings" and it will open the setting where you have to activate the reactivation lock (maybe isn't necessary, but that way worked) but this time using your samsung account. Then you just have to do a factory reset (from the settings, not from the recovery) and your phone will be unlocked. It will restart and then you can set it up normally. Hope this works for you as it do for me.
Warning:
After that's all ok, go to SETTING>GENERAL>SECURITY and UNCECK "LOCK MY PHONE AFTER FACTORY RESET OR WIPE!!!
UPDATE IMMEDITLY WHITH OTA LAST UPDATE FOR TO HAVE THE "REACTIVACTION LOCK OFF BUTTON in Above Directory,
NOW YOU PHONE IS PEFECTAMENT WORKING and WHITH YOU SAMSUNG ACCOUNT, WARNING FIRST OF WIPE/F.RESET OF CECK IF "REACTIVATION LOCK BUTTON IS "UNCECKED", that's all, if this can help many of you, thanked if you want,
Max
BIG THANKS to my Friend Moderator
MOULNISKY
ALEX
The Following 5 Users Say Thank You to allumts For This Useful Post:
Old 06-19-2014, 13:29   #4 (permalink)
.:Ripgsm:.'s Avatar
Member: 125945
Thanks Meter: 495
how to bypass/fix reactivation lock samsung galaxy note 3 [KitKat 4.4.2] with VIDEO, how request:
How To Bypass/Fix Reactivation Lock - Blocked Samsung Account Samsung Galaxy Note 3 [KitKat 4.4.2] - YouTube
Warning, all other thread are BIG copy/past from my work, the unique that helped me with one link is our mod. Moulnisky
Ripgsm
Old 06-21-2014, 14:08   #5 (permalink)
Crazy Poster
Member: 1916342
Thanks Meter: 11
thanka ripgsm
Old 07-18-2014, 12:08   #6 (permalink)
allumts's Avatar
Member: 1564612
thanka ripgsm
This is my UNIQUE and ORIGINAL thread from my Team all other posted in this forum are only Copy/past from our work,
Please press Thanks Button, no Thanks post, it's Out of rules forum
allumts
The Following User Says Thank You to allumts For This Useful Post:
Old 09-30-2014, 04:40   #7 (permalink)
Member: 1309482
Thanks Meter: 26
Hi every one!. I have a Samsung sg-900h. And try your tuto, but dont work. Any help with this model?. Thanks!.
Old 09-30-2014, 13:07   #8 (permalink)
allumts's Avatar
Member: 1564612
Hi where you have read that work for S5 G900h? this procedure is only for NOTE 3 N900/N000X last time read good please.
Regards
allumts
Old 09-30-2014, 13:30   #9 (permalink)
Member: 730798
Thanks Meter: 48
Regards
allumts
Checked on my Sm-G900F -> solution works fine, unlocked.
The Following 2 Users Say Thank You to exprxp For This Useful Post:
Old 09-30-2014, 13:36   #10 (permalink)
allumts's Avatar
Member: 1564612
Good, so work also in S5 all variant.
Who not is good re try other time reading carefully the procedure.
allumts
Old 09-30-2014, 13:43   #11 (permalink)
Member: 730798
Thanks Meter: 48
On S5 buttons can be renamed or set on another place, but process the same, connect to WiFi and blah blah blah
Old 02-12-2015, 00:08   #12 (permalink)
mustafa_180's Avatar
Member: 638097
Sonork: 100.1649741
Thanks Meter: 43
Guyes I have done 4-5 pices note3 & galaxy s5 android 4.4.2 ,but now i m unsuccesfull on galaxy s5 android 5.0, have any way to Bypass the samsung acount from android 5.0 of galaxy s5 .thanks guys .
Old 02-15-2015, 11:37   #13 (permalink)
allumts's Avatar
Member: 1564612
For all you that have problem for understand this easy procedure, here other VIDEO where show "How To" for Remove Samsung Account, working also in all Note version and Galaxy S5 4.4.4, not have tested with "lollipop update".
HERE:
How To Bypass / Remove Reactivation Lock on Samsung Galaxy Note 3 / S5 - Locked by Samsung Account
allumts
Old 03-16-2015, 07:11   #14 (permalink)
Member: 2249621
Thanks Meter: 22
i think can remove it install cwm recovery put in recovery there need delect file but i dont know which is it who have idea about it
The Following User Says Thank You to aram701 For This Useful Post:
Old 03-16-2015, 10:19   #15 (permalink)
allumts's Avatar
Member: 1564612
You not have need of any CWM, must need only read/Lock and Apply procedure for REMOVE SAMSUNG ACCOUNT, nothingh more.
Which Recovery...whtat Delete file....but you have read procedure, Loock video or what are you do for post this question?
Page generated in 0.30189 seconds with 9 queries
