Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
11-17-2013, 23:49 | #1 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Galaxy Note 3 N9005 Reactivaction Lock Samsung Account Problem Is loked in Samsung Account, from Download Mode can flash any Fw whith success but there is ENABLED Write ON, anybody can help for get out from this mode or recovery in LOCK WRITE OFF?, thank in advance Br Max |
11-18-2013, 13:57 | #2 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hello, have find this NEW over REACTIVACTION of LOCK OFF: International Galaxy Note 3 getting another OTA, reactivation lock now defaults off | Android Central Loock Here: Anybody know if is possible to flash this update, (i'm not have this Fw base UDMJ6), only via Sd Card or Full Fw always via Sd Card and if Solve this Problem?, thank in advance |
12-04-2013, 11:36 | #3 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Solved note 3 n9505 samsung account FOR ALL USER WHITH NOTE 3 N-9505 that have Wiped/Factory reset your phone and now have only SAMSUNG ACCOUNT request Locked in the SCREEN, here a little, speed and Tested By to me SOLUTION: First Solution Tested and Working: Goto accessibility option which is available on the first screen where you select language..then goto Text to speech option..then from the settings goto Install voice data and try to download any language..It will ask you to enter samsung account details...Enter your own samsung account details..once the download is complete..go back to screen where it was showing abnormal factory reset adn then enter your samsung account..It will go through.. Second Solution Tested and Working: First of all I have to say that I've created this account just to share what I did with this problem. It took me, after doing dozens of hard reset and flashing firmwares, 10 minutes. Maybe, the seller never activated the phone (that's what happened to me) and this screen is appearing by mistake. So what you have to do if this is your case is to connect the headphones that came with the phone and press the button for 1-2 sec. Then the SVoice will apear and there you can use voice commands. So you just say "Start Settings" and it will open the setting where you have to activate the reactivation lock (maybe isn't necessary, but that way worked) but this time using your samsung account. Then you just have to do a factory reset (from the settings, not from the recovery) and your phone will be unlocked. It will restart and then you can set it up normally. Hope this works for you as it do for me. Warning: After that's all ok, go to SETTING>GENERAL>SECURITY and UNCECK "LOCK MY PHONE AFTER FACTORY RESET OR WIPE!!! UPDATE IMMEDITLY WHITH OTA LAST UPDATE FOR TO HAVE THE "REACTIVACTION LOCK OFF BUTTON in Above Directory, NOW YOU PHONE IS PEFECTAMENT WORKING and WHITH YOU SAMSUNG ACCOUNT, WARNING FIRST OF WIPE/F.RESET OF CECK IF "REACTIVATION LOCK BUTTON IS "UNCECKED", that's all, if this can help many of you, thanked if you want, Br Max BIG THANKS to my Friend Moderator MOULNISKY ALEX |
The Following 5 Users Say Thank You to allumts For This Useful Post: |
06-19-2014, 13:29 | #4 (permalink) |
No Life Poster Join Date: Mar 2005 Location: tuttotelefonia
Member: 125945 Status: Offline Thanks Meter: 495 | how to bypass/fix reactivation lock samsung galaxy note 3 [KitKat 4.4.2] with VIDEO, how request: How To Bypass/Fix Reactivation Lock - Blocked Samsung Account Samsung Galaxy Note 3 [KitKat 4.4.2] - YouTube Warning, all other thread are BIG copy/past from my work, the unique that helped me with one link is our mod. Moulnisky Br Ripgsm |
07-18-2014, 12:08 | #6 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Please press Thanks Button, no Thanks post, it's Out of rules forum Br allumts | |
The Following User Says Thank You to allumts For This Useful Post: |
02-12-2015, 00:08 | #12 (permalink) |
Freak Poster Join Date: Nov 2007 Location: Bangladesh
Member: 638097 Status: Offline Sonork: 100.1649741 Thanks Meter: 43 | Guyes I have done 4-5 pices note3 & galaxy s5 android 4.4.2 ,but now i m unsuccesfull on galaxy s5 android 5.0, have any way to Bypass the samsung acount from android 5.0 of galaxy s5 .thanks guys . |
02-15-2015, 11:37 | #13 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | For all you that have problem for understand this easy procedure, here other VIDEO where show "How To" for Remove Samsung Account, working also in all Note version and Galaxy S5 4.4.4, not have tested with "lollipop update". HERE: How To Bypass / Remove Reactivation Lock on Samsung Galaxy Note 3 / S5 - Locked by Samsung Account BR allumts |
03-16-2015, 07:11 | #14 (permalink) |
Freak Poster Join Date: Aug 2014
Member: 2249621 Status: Offline Thanks Meter: 22 | i think can remove it install cwm recovery put in recovery there need delect file but i dont know which is it who have idea about it |
The Following User Says Thank You to aram701 For This Useful Post: |
03-16-2015, 10:19 | #15 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | You not have need of any CWM, must need only read/Lock and Apply procedure for REMOVE SAMSUNG ACCOUNT, nothingh more. Which Recovery...whtat Delete file....but you have read procedure, Loock video or what are you do for post this question? |
