Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 09-12-2011, 19:13   #1 (permalink)
Member: 366425
Thanks Meter: 22
galaxy s i9000 restart problem
hi, i have i9000 galaxy s restarting when i recieve it from customer for repair...
i flashed with odin downloader but still restarted,..
repair by riff but still problem persist
mobileis restaring
ive used these file:
GT_I9000_JPJV6_JXJV6_OJPJV6_Sbl with 512.pit
I9000JHJV8 w/ 512.pit
I9000XXJVR SWC w/ 512.pit
all of those were unable to repair i9000,but im sure those files were working as i have tested by me personally before,
maybe a firmware compatibility?
by the way ive got 4 pcs before with the same prob and still got no idea
these mobiles were purchased here in saudi arabia so im guessing i should be using an arabic firmware like those above...
pls help need some enlightment
Old 09-13-2011, 20:03   #2 (permalink)
Member: 366425
Thanks Meter: 22
anyone?? pls help...
thanks
Old 09-14-2011, 20:40   #3 (permalink)
tsarkh's Avatar
Member: 165812
Sonork: 100:1627635
Thanks Meter: 4,261
Look Bro For Tested Guide Check Here
Then Try This:
Get this FW I9000XXJPU and flash three files with pit too
Phone must be on and work.
After that Take this FW for Arabic 2.3.3 and flash it without pit file to make it arabic
Share If U Care
The Following User Says Thank You to tsarkh For This Useful Post:
Old 09-15-2011, 15:43   #4 (permalink)
Member: 366425
Thanks Meter: 22
thanks tsarkh,you are always no.1 in regards to samsung mobile
ill try your procedure,... be back after flashing for results
thanks again
Old 09-15-2011, 17:10   #5 (permalink)
Member: 366425
Thanks Meter: 22
id tried tsarkh procedure but still doesnt work....
im beggining to lose hope...
any other way?
theres an error and it says:
E: failed to mount data (file exist
E:delete_data_files:cant mount /data
your storagenot prepared yet,please use ui men
u for format and reboot action
Old 09-15-2011, 20:31   #6 (permalink)
Member: 366425
Thanks Meter: 22
ok, i kinda sort out the problem, the phone did boot up regardless of what version i put on,but the memory card (4gb) should be inserted. in short,in order for phone to boot up normally there should be a memory card inserted
and when i browse in "my files" it says no memory card inserted and inside settings > sd card > it says not available
pls someone have an idea on this?
thanks
Old 11-11-2011, 11:35   #7 (permalink)
vazgsm's Avatar
Member: 111871
Sonork: 100.78975
Thanks Meter: 100
ive got same situation here, did u manage to get a solution for that?
Old 02-06-2014, 09:23   #8 (permalink)
Member: 1922187
Sonork: 100.1649675
Thanks Meter: 2
me also got a same problem any one solve this then tell us
requested
Old 07-10-2015, 11:58   #9 (permalink)
Member: 2133973
sir i have same restart problem with samsung galaxy i9000. plz ask me solution for it
Old 07-10-2015, 23:03   #10 (permalink)
Member: 125632
Thanks Meter: 232
Talking
you se this after flashing...
your memory built into the i9000 is either wrong format,or totally xxxxed,or you have done the memory mod lag fix
all is explained at this link
http://forum.xda-developers.com/showthread.php?p=30415128#post30415128
you will need to read from 11 to 14
all is explained easily,how to fix this prob....
good luck all
note to mod,,,please allow this link,as it has all the ans for probs with the i9000....thanks to "xsenman"
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-16-2013 09:16
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 16:21
6110 5.47 sw unlock problem gsms Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-21-1999 19:43
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 01:44
Page generated in 0.31769 seconds with 8 queries
