Galaxy S4 GT-I9500 Repair IMEI "NULL/NULL" Necessary Files / / Odin v3.07.zip; / / GT-i9500 fix_imei_null.zip; http://img10.imageshack.us/img10/5518/sqm.png - Open Odin - Extract the. ZIP file, place the file in PDA [the phone has to be switched to Download Mode] - Press START - End! : -)) That's it, simple steps to retrieve the IMEI of S4, damaged by trying to change the imei with another model. Note;If after these steps the imei still null/null then the problem is hardware,this tested on 2 phones with imei null,after write this file the imei back to original http://www.mediafire.com/download/61..._imei_null_new regards Pablo ;) |
thanks its working now |
Hello, My name is Angel. I have problem with the imei of my S4 GT-I9500, it's not null but it's the fake one(004999010640000/01) I've been searching for the solution for long time now...no box can confirm repairing imei of model I9500 yet. So, I'd like to ask is this work for fixing the fake imei also?... Thank you so much. Best regards, Angel S. |
yes this problem i know,you have imei 0049xxxxx why write a efs from other from you,this damaged and show default imei damaged. to solution this problem you need wait for any team released repair imei to this device. Good Luck! Pablo |
Thanks. Someone have only efs default file? |
need help pablo <ID:0/049> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> MD5 hash value is invalid <OSM> GT-i9500 fix_imei_null.tar.md5 is invalid. <OSM> End... |
http://www.mediafire.com/download/61zvhbf5c9a46dc/GT-i9500_Fix_imei_null_new |
problem solved rename GT-i9500 fix_imei_null.tar.md5 to GT-i9500 fix_imei_null.tar adn work wait finish and repair my phone |
Hey thanks, it worked fine.... Do you have similar tips for Galaxy S3 as well. Or can I try this one on that model as well, as both of them are almost similar ones. But as you said it's exclusively for S4 so I am quite confused. |
can i use this file for i9505 |
Good Luck! |
i downloaded GT-i9500_Fix_imei_null_new.zip ,extract it and rename to .tar and flashed but my problem not solved |
it worked perfect for me....thanks a million..(LPH) Love, Peace, and Happiness..:) |
please give me right way to flash this file |
OP, thank you for the file. My question, how does this .tar differ from a stock .tar? what changes did you make? I'd like to do this on other GS4 models... SPH-L720 specifically. |
vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
