Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 07-10-2013, 06:37   #1 (permalink)
Member: 1159099
Thanks Meter: 6,371
Lightbulb Galaxy S4 GT-I9500 Repair IMEI "NULL/NULL"
Necessary Files
/ / Odin v3.07.zip;
/ / GT-i9500 fix_imei_null.zip;
- Open Odin
- Extract the. ZIP file, place the file in PDA [the phone has to be switched to Download Mode]
- Press START
- End! : -))
That's it, simple steps to retrieve the IMEI of S4, damaged by trying to change the imei with another model.
Note;If after these steps the imei still null/null then the problem is hardware,this tested on 2 phones with imei null,after write this file the imei back to original
http://www.mediafire.com/download/61..._imei_null_new
regards
Pablo
Last edited by xcachorrox; 07-16-2013 at 01:31. Reason: add new link direct to download :--)
The Following 50 Users Say Thank You to xcachorrox For This Useful Post:
Old 07-10-2013, 07:24   #2 (permalink)
Member: 525940
Thanks Meter: 213
thanks its working now
The Following User Says Thank You to eumore79 For This Useful Post:
Old 07-12-2013, 18:34   #3 (permalink)
Member: 1963047
Hello, My name is Angel. I have problem with the imei of my S4 GT-I9500, it's not null but it's the fake one(004999010640000/01) I've been searching for the solution for long time now...no box can confirm repairing imei of model I9500 yet.
So, I'd like to ask is this work for fixing the fake imei also?...
Thank you so much.
Best regards,
Angel S.
The Following User Says Thank You to 666.NightAngel For This Useful Post:
Old 07-13-2013, 01:04   #4 (permalink)
Member: 1159099
Thanks Meter: 6,371
Thank you so much.
Best regards,
Angel S.
Hi Angel!
yes this problem i know,you have imei 0049xxxxx why write a efs from other from you,this damaged and show default imei damaged.
to solution this problem you need wait for any team released repair imei to this device.
Good Luck!
Pablo
The Following 3 Users Say Thank You to xcachorrox For This Useful Post:
Old 07-13-2013, 11:16   #5 (permalink)
Crazy Poster
Member: 347273
Thanks Meter: 8
Thanks. Someone have only efs default file?
The Following User Says Thank You to mavr15 For This Useful Post:
Old 07-16-2013, 01:28   #6 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
Thanks Meter: 370
need help pablo
<ID:0/049> Added!!
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> MD5 hash value is invalid
<OSM> GT-i9500 fix_imei_null.tar.md5 is invalid.
<OSM> End...
The Following 2 Users Say Thank You to jmr For This Useful Post:
Old 07-16-2013, 01:31   #7 (permalink)
Member: 1159099
Thanks Meter: 6,371
Originally Posted by jmr View Post
need help plablo
<ID:0/049> Added!!
<OSM> Please wait..
<OSM> End...
strange i test here,download again from this new link
http://www.mediafire.com/download/61zvhbf5c9a46dc/GT-i9500_Fix_imei_null_new
The Following 4 Users Say Thank You to xcachorrox For This Useful Post:
Old 07-16-2013, 01:44   #8 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
Thanks Meter: 370
problem solved rename GT-i9500 fix_imei_null.tar.md5 to GT-i9500 fix_imei_null.tar adn work wait finish and repair my phone
The Following 5 Users Say Thank You to jmr For This Useful Post:
Old 07-31-2013, 11:15   #9 (permalink)
Member: 1900437
Thanks Meter: 113
Hey thanks, it worked fine.... Do you have similar tips for Galaxy S3 as well. Or can I try this one on that model as well, as both of them are almost similar ones. But as you said it's exclusively for S4 so I am quite confused.
The Following 2 Users Say Thank You to Promo87 For This Useful Post:
Old 08-01-2013, 21:44   #10 (permalink)
zakryia's Avatar
Member: 640361
Thanks Meter: 77
can i use this file for i9505
The Following 2 Users Say Thank You to zakryia For This Useful Post:
Old 08-02-2013, 05:31   #11 (permalink)
Member: 1159099
Thanks Meter: 6,371
this firmware is to I9500,but you can try.
Good Luck!
The Following 2 Users Say Thank You to xcachorrox For This Useful Post:
Old 08-02-2013, 16:27   #12 (permalink)
iArkAt8's Avatar
Member: 1744310
Sonork: 100.1617232
Thanks Meter: 43
i downloaded GT-i9500_Fix_imei_null_new.zip ,extract it and rename to .tar and flashed but my problem not solved
The Following 2 Users Say Thank You to iArkAt8 For This Useful Post:
Old 08-03-2013, 04:33   #13 (permalink)
Member: 1940476
Thanks Meter: 27
it worked perfect for me....thanks a million..(LPH) Love, Peace, and Happiness..
The Following 2 Users Say Thank You to vinslyj For This Useful Post:
Old 08-03-2013, 13:18   #14 (permalink)
iArkAt8's Avatar
Member: 1744310
Sonork: 100.1617232
Thanks Meter: 43
please give me right way to flash this file
Old 08-04-2013, 01:08   #15 (permalink)
Member: 289504
Thanks Meter: 6
OP, thank you for the file.
My question, how does this .tar differ from a stock .tar? what changes did you make? I'd like to do this on other GS4 models... SPH-L720 specifically.
The Following User Says Thank You to autoprime For This Useful Post:
Page generated in 0.20868 seconds with 9 queries
