-   Samsung Android based phones (http://forum.gsmhosting.com/vbb/f777/)
-   -   Galaxy S9 FRP REMOVED 100% DONE (http://forum.gsmhosting.com/vbb/f777/galaxy-s9-frp-removed-100-done-2449757/)
wivan 08-11-2018 11:29
This method has been tested with [Samsung S9 SM-G960F Android 8].
Steps:-
-First, you need power off your device...
-Then put your Device in Recovery Mode.[Press & hold Vol UP+Bixby Key+ Power Key] When you see android logo release all the keys.
- After some time you will see the Recovery Menu on your device.
-Check your Device Firmware version and bootloader version.
-Then download Same firmware version Combination File form Below.
After that, you need to flash combination firmware
Download Odin from Below.
Then Extract Odin and G960F combination Firmware on your Computer.
After that, Open Odin extracted folder.
Then, Run Odin.exe
Click on "AP" tab and select Combination file.
Then Put your device in Recovery Mode.[Press and hold Volume Down + Bixby key + Power key] Confirm to press Volume UP key.
Then Connect your device to PC.
-After that you will see "added" massage On Odin log box.
-Then tap on "Start" button on the Odin tool.
-Wait for flashing finished.
-Then Power On your Device.
-Then Swipe up to down your finger to bring Notification Menu.
-Then tap on the Settings icon.
-Then go down - About device - software info.
-then tap build number 7 times.
-Then go back to the settings menu.
-Goto developer menu.
-enable Oem unlocking and USB debugging.
Then back to "Factory Binary" main menu.
-Then tap on IME Option.
Then Put *#0808#
Then select DM+ACM+ADB
-Then tap on reboot.
-After power on.
-Connect your device again in PC.
-Download FRP Tool By GD.
-Extract and Run FRP tool (GD)
-wait for completion.
-After that, Download Samsung S9 SM-G960 stock firmware from below
Now Flash Stock firmware on your Device ..
Done...
Mobile-Lab 08-21-2018 00:52
Samsung Galaxy S9, S9 Plus FRP/Google account bypass | SM-G960U, SM-G965U FRP/Google ID bypass
http://www.youtube.com/watch?v=UbZbQmkBz78
dragosgsm 09-01-2018 09:40
this doesn't work on bit2 update,anyone has bit2 combination file?
himcom 09-01-2018 12:07
SAMSUNG S9 SM-G960F :
COMBINATION_OXM_FA80_G960FXXU2ARG2_OXMFAC
SAMSUNG S9+ SM-G965F :
COMBINATION_OXM_FA80_G965FXXU2ARG1_OXMFAC
Mobile-Lab 09-01-2018 23:13
bit2 combination can be found on Z3X server
and method is very simple, first flash combination firmware
then OEM ON from settings and make factory reset
put in download mode, it will show FRP OFF, then flash stock.
yonic69 09-02-2018 01:13
That is correct! done and certified.
asad_nomy7 12-20-2018 19:41
Bit 2 tested solutuion without PC.
http://forum.gsmhosting.com/vbb/f777.../#post13472409
zubairhussain 04-25-2019 17:38
anyone have binary 3 combination for this model?
harberjack 08-17-2019 15:04
samsung sm-g960u u6 Frp Solution
COMBINATION_FAC_FA80_G960USQU6ASG1_FACFAC_CL132301 90_QB24634750_REV01_user_mid_noship_MULTI_CERT
pazot 11-02-2019 09:41
What about binnary 7(G960FXXU7CSJ1) ? I could not find instructions anywhere...
estagent 11-08-2019 17:46
how solved problem FRP bit U7 security patched?
Mobile-Lab 11-08-2019 18:01
http://forum.gsmhosting.com/vbb/f777...amage-2720388/
Page generated in 0.26698 seconds with 5 queries
